']im well aware that they are pnp for the car they are made for, sk was saying that to make it pnp on nicks car, he would have to change a few things... thats no longer pnp is it
SK didnt say thats what you have to do to make it Plug and Play, he said thats the 'method' you have to use to make it work.
  • Replies 66
I looked into the r32 loom, theyre at a premium due to their repective ecu being able to be chipped, the few i did find had people asking ridiculous prices Certainly isnt a plug and play when you have to change looms, Esp when plugs need to be changed etc.
Nismoid, playing with a wiring loom is far from being 'just a few wires' its a godamn headache. Yet again please post or have those who have 'switched' looms post here.
Something to keep in mind is that if you have an R32 or car with a similar chipable ECU is just getting it re-tuned with a custom chip. If I remember correctly the factory ecu is at least as good as a PFC in terms of drivability.
This is probably only good for people like me who only intend to get the car tuned once or maybe twice but then again there are a lot of us who dont need to constantly retune the car.
not getting a whole 32 loom.
playing with the existing one which is a few wires in terms of how many there are.
If people can get a 32 silver ECU to go on a red-top without too much hassle then it cant be hard or cost mega $$$
Getting back to Link ECU's, had on for bout 4 years. Had it on a manual 33 and auto 33. I have no problem admitting that i feel shattered, its been a ball breaker over the years to fine someone who can tune it. On both Manual and auto theres no bottom end, stalling the auto is gone revs stop going up after 1100rpm.
The problem lies in the tuning or lack of it available, i have taken it out and has been sitting on my shelf for over a year....actually if anyones interested i'll sell the focker, map sensor included obvisiously. So this from someone who has experienced it rather than debating wether its any good or not. Believe me, avoid the Link...damn just botched any chance of me selling it!
    • it takes so long to get things done but ... they are nearly there and we hitting the track soon again  So - at Perth Festival of Speed the car unfortunately had a decent off, wasnt me driving, wasnt the person drivings fault. Long story short car got sent very fast towards the wall without the control on throttle from the driver input and a disaster was averted but there was damage that needed to be fixed - carbon busted and alot of bent bits The splitter got munched and had to go back to get fixed - took a bit to get it there, fixed and back but got a surprise package when a new double element higher DF splitter came back - nice surprise !  and first person to have one     At a car show I took the car too some punks stole one of my carbon indicator blanks and stomped on the other so had to get a new set of headlight / indicator combo from tops stage so got front fender vents as well to put in the order     While all this was happening the new MCA golds turned up and did some fiddling around with those   Put in the flappy paddle system and clutch lockout wiring/ system   We have also put shorter gearing in top top it out at 300 kmph in 6th gear  where previously I held 5th to 282 at SMP and 277 in Perth   Looking for better control and faster acceleration     I wasnt intending on doing pedal box I was managing with the brake master replacement system I had going on and adjusted std pedals but on applying the clutch switch to the old system we found the *insert technical word here * bar that goes from the pedal to the master was bent about 40 deg and about to snap = lucky find otherwise be a bad bad time - discussion was had about getting a custom bar built to withstand the load but in reality it was time      making any suspension, wheel or anything adjustments to date has been a nightmare - aero off, adjust, check and repeat - time consuming and hard - short of going full airjack system we fashioned some external manual car lifts this will make life a million times easier     All the bent framing, some intercooler pipes and other has been fixed and replaced and after 6 months I finally have the car back at home in my control so its get to work on it, set ride heights, wheel align and will start track testing again soon   So ultimately other than a few flashy bits nothing actually looks likes its been done but in reality alot has. Typical   We'll see how all this goes
    • I'm far from an expert, but for sticking bits of metal together occasionally I got a MIG, the biggest one I could get with a 10a plug (because while I have some 15a GPOs around, they are not everywhere).  Also, because I get through SFA, I just buy the small disposable gas bottles at Bunnings, I'm not opening a BOC account to get through 1/10th of a full size bottle each year
    • FWD is different though.
    • Ignore the BOV / recirc valve question. You have an NA and shouldn't have one. If there magically is one though... It should be removed, though it shouldn't really effect it in the way one will for a turbo motor with it venting to atmosphere while running an afm.
