I thought the GTS (non turbos) in R33, all came with LSD as well.. unless on purchase in japan it was optioned out of the spec list to save a whole $500 or something ??
It's possible the GTS had non-viscous type however (similar to R32 gts-t)..
https://www.sau.com.au/forums/topic/66405-r33-diffs/#findComment-1237793
hmm you may want to check this out, but i think the N/A diffs have shorter gears which is a good thing if you are looking for faster acceleration. All standard LSD's in the nissans are pretty crap, and will start single wheeling when you give them constant sh1t.
If you want proper LSD, get a decent 2-way diff, or weld it up if you wanna save cash =)
https://www.sau.com.au/forums/topic/66405-r33-diffs/#findComment-1238868
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
