I was wondering what are the differences in the BNR32 and HCR32 ???
also ive noticed that some standard injectors on the r32 are yellow on the connectors .. but when i checked mine out they are standard too but red connectors.
are there any differences power/ aftermarket or are they just the same.?
responses would be appreciated.
thankz!
:flamed:
https://www.sau.com.au/forums/topic/66413-what-are-the-differences/
My RB20DET injectors have a clear slightly heat damaged yellow tinge with a red dot on the tops.
Generally the RB20DET injectors are red.
Maybe they ran out of red plastic when making mine and decided to put a red dot on them. :)
My R32 is a late 1992.
The GTR standard injectors are 440cc, are yellow/mustard in coloring, generally the coloring of injectors is not the defining factor, check the aprt number, some people like to paint there injectors, so check the part number to be sure..
BTW, I used to ahve standard GTR injectors, but now I ahve SARD 700cc jobbies that are a really pretty blue color.. :)
    • Does that price include the rack time to straighten the frame and body and replacement of parts and paint, as well as the noise and emmisions testing  The last engineering certificate I had done, albeit about 15 years ago, was around $1000 for a few inspections and the certificate
    • 😂 thanks guys. The diagram i had did not have the breather on it at all. Much appreciated.
    • Geez, engineers fees have definitely gone up. Mine back 2007 cost me all of $300. Mind you, I had to go back to him a few times to get him to write the correct things on the report after he'd inspected it. Things like wrong exhaust size, wrong wheel sizes, etc etc.
    • Can we see a scan of the original quote? The problem with engineers (and by this, I mean, all engineers across all engineering industries) is that there are "engineers" and there are "engineers" (you'll have to imagine the two different vocal emphases on those two versions of the same word. Engineering is a mindset - your farm kid who spent his life rebuilding the tractor will likely make a good engineer. The farm kid who spent his life taking photos of butterflies.. perhaps not. But on top of that mindset, the modern engineer has to learn how to write so that there is absolutely no way of being misunderstood. Proposals/budget estimates/quotations are one place where this is absolutely vital. You have to delineate your scope of supply with extremely hard boundaries, and anywhere where there is any possibility of not being able to have such a hard boundary, you need to write language that will cover you from scope creep, cost overruns, the inevitable interference of the client or their "engineer", etc etc. Now, if your clients are the BHPs and the Rio Tintos of the world, and similar, then you get good at this. If you are an automotive engineer, pitching work to the great unwashed masses, your skills in this area might not be well developed, because you're only dealing with knuckle draggers trying to get a big block legal in a Torana. And when I say "might not"....I'd suggest there's a better than even chance that any such skills might be completely absent. So, we might be able to look at your quote and see what the opportunities are for rebuttal.
