Mmm just read what happened in the skyline downunder thread u wrote PVA
Im glad you won, they acted like utter jerks and what gave them the right to suddenyl decide to give u the ticket for a car related offence when they decided you were being cheeky??
Makes no sense to me.
Anyway I think ill be going to court for an Undue n Excessive Noise fine and its byebye license if I lose. I chirped 2nd on Leach hwy without intending to - one moment of many bad coordination between accel n clutch hahahaah
But yeah the cops were absolute w**kas to me that evening. I dont have a very high opinion of police anymore
https://www.sau.com.au/forums/topic/6645-glue-story/page/2/#findComment-99421
I went to work's liberary and got me self "Traffic Offences Book".
I just red one chapter and there are so many things cops can not do, like randomly stop you with no ground and ask you pop the bonnet etc... police have no power to do so!. unless there is resonable doubt that you are suspected crime or traffic offence etc..etc.
I'll let you people know my findings...
Cheers
Joe :P
https://www.sau.com.au/forums/topic/6645-glue-story/page/2/#findComment-99430
Hmm, undue and excessive noise for a chirp, was it just a chirp, 'cause if it was that really sucks the big ones. Next thing you know, if you lock up your wheels when braking to avoid an accident (eg a pedestrian, or small fluffy animal) they will get you for it as well, "Yes well done avoiding that young child chasing that ball, now here, cop this - next time don't brake so hard" - wouldn't put it past some of the idiots out there.
S13, I hope you have made a formal complaint, enough people make complaints about these #$%k heads and if nothing else it may make life harder for them - can only wish
Good luck in court
Steve
https://www.sau.com.au/forums/topic/6645-glue-story/page/2/#findComment-99435
Cheers
Joe :P
Dude this sounds like a great idea, "PVA's definitive guide to police harrassment" - bring it on
https://www.sau.com.au/forums/topic/6645-glue-story/page/2/#findComment-99464
The thing with the law is it's abiguity. It's not clear and left to the descretion of the Officer (or Judge ) involved. A cop can just say I reckon thats not stock and not legal and thats it you have to pop the bonnet. However if the car is in your driveway you can polietly ask them to get a warrant...
But you gott admit it Joe there sure isn't anything better than watching a Judge tear strips into a cop...
https://www.sau.com.au/forums/topic/6645-glue-story/page/2/#findComment-99508
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
