  • Replies 51
You may also notice that you put the clutch fully down and you recieve a small notch of the gearbox when putting into gear/into another gear - this is because the clutch is not dissengaging properly because of the fault in the clutch hydraulic system (the master/slave cylinders)
Can you explain that a bit?
My clutch is sqeaking at the moment, and has for a couple of weeks. Sometimes first gear is hard to engage... Haven't had time to check if its internal or external, but I am guessing external.
Lucien.
Im currently in the process of making some beefed up clutch pedal boxes because the one in my r32 broke.
It managed to snap the two spot welds on the left side, put 2 cracks in the top (piece fell out after reomoving pedal box), and had a split in the top where it bolts up the top under the dash. This was after a year of using a 9 puk xtreme ceramic button clutch, and 6 months of an OS Giken twin.
Would there be any interest for some made up for r32 or r33? Just seeing as im making one, i may as well make a few....
will post pics of std r32 unit soon and then the beefed up version, made out of thicker steel etc....
Hi guys,
What does it mean if i have difficulty engaging 2nd gear.
This only happens when i reve the car in 1st gear very hard up till about 40-50km/h. I don't have this problem if I change to 2nd gear at about 20-25km/h.
I have no squeaks whatsoever and engaging every other gear is smooth.
Please help me out guys!!!
Dan
  • 1 month later...
Right, my clutch is getting worse.  Damn squeeky.  Reverse is a bitch to get in to and so is second gear.  Are these symptoms indicative of the boost/master cylinder leaking?
Cheers,
Lucien.
Sounds more like a gearbox problem than the clutch if gears are hard to get into.
I don't think so. I think the clutch isn't engaging/disengaging properly. If I pump the clutch the shifts get easier, which to me suggests a seal is leaking.
Edit: Whoops.. "shifts" :)
Lucien.
if you can pump it up and it gets easier to engage gears then it's almost certainly an hydraulic problem like you suggested. get underneath the car and have a look at the slave (it's just bolted to the box) peel back the rubber boot and if there is fluid in there then it's leaking. a new slave is only like $70 or thereabouts so you should just buy a new one. very easy to change. if that doesn't fix it your master may be on the way too. unfortunately they cost more and are harder to replace.
Sorry, I got a phone call part way through the post so I didn't add all the details :)
The selection problem and the clutch noise seem to have arisen at about the same time. As the clutch has gotten louder the selection problem has gotten worse.
First gear can be tough to get in, but because the car is usually stationary, its not too bad. Entering second, however, is on the move and is proving more difficult. The problem is particularly evident if I haven't driven the car for awhile.
Richard: What about those seal replacement kits for the master cylinder? Worth a look?
Edit: few more things.
If the car is stationary and I go through the gears (clutch depressed) it feels fine. Likewise if the car is off, I can go through the box without any obvious problems.
Lucien.
ahhh, if car moves through the gears ok when stationary then it may not be hydraulics. they are worth replacing anyway though, and if they solve your problem that's a bonus.
if you are going to put new seals in your master you will need to have it checked as they don't always wear true. if it hasn't they can bore it out and install a steel sleve in there (which once assmebled with piston+seals will be better than a new stock one) only problem is a recconditioned master (bore, sleeve, piston, seals) costs about as much as a brand new one from nissan. it is better though.
as far as your problem goes it sounds like it *may* be gearbox related, BUT, I would certainly eliminate any clutch issues first (they are cheaper!). start with hydraulics (master, slave, line) then you will have to look at clutch (release bearing, pivot, pressure plate, friction plate), and if all those are ok it's gearbox time.
have you changed the gearbox oil since you got the car?
Gearbox oil was changed almost straight off the boat :) Its running Redline at the moment. Almost no shavings on the plug magnet.
My inclination is still that its hydraulic. I'll check out the slave cylinder as you suggested :) I have a replacement clutch line ready to install anyway, so that will eliminate another possibility.
Lucien.
yep when I got my car I replaced the slave. unfortunately it already had a nismo slave on there so whilst I got more positive clutch disengagement I did gain a MUCH heavier pedal feel (i have a twin plate OS Giken clutch), I also have a braided clutch line which I'm sure helps a little.
edit: what type of rediline oil are you using?
hahaha, yes I am burdend muchly.
Seriously though the twin plate clutch I have is a bit of a bitch. quite heavy pedal (used to be light with the nismo slave d'oh), very little communication (hard to judge 'take-up point), VERY BITEY, squels (un sprung, brass plates) and rattles when disengaged plus the box is quite tricky. MUST heal and toe down shifts, and when at a stand still always move it to second, then first.
However, when you are giving it some it alway works absolutely flawlessly. shifts oh so smoothly at 7000rpm++, does lovely smoking burnouts without clutch slips. launches at 6000rpm+ without slip or broken box. love it.
edit: I must say I have heard people advise against redline SP for GTR boxes. And I do know of one person who complained of gear selection problems after switching to it. I do believe it's what Redline reccomend though isn't it?
Took the car round to Grey Imports so they could have a look at the slave: sadly not a drip of oil. Nath played with the clutch and gearbox for a bit. Prognosis: expensive :rofl: The clutch is probably dead. I wouldn't be suprised if it has worn unevenly too given the way it sometimes dis/engages perfectly and others times refuses.
Now just to pick a clutch .. oh, and spread wide :P
Lucien.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
