Hey Shodo,
Welcome aboard the SAU Express.
This is one of the most informative Skyline sites on the Internet and most people would be happy to answer your questions.
All we ask is that before you post a question, use the 'search' function first as it is most likely your question has been answered before.
Good luck with it all.
https://www.sau.com.au/forums/topic/66466-new-fella-here/#findComment-1237623
