People could please make sure that if you do have these rims they are not the 6.5inch wide version. They are stamped 16/7.5 45 offset on one of the inside spokes.
These rims are possibly off the AWD non GTR Skylines not sure. But I have definately got two 7.5inch wide R33 Skyline Rims and I want 2 more.
Or will take 4
https://www.sau.com.au/forums/topic/66467-wanted-2-standard-r33-1675-inch-rims/
my stockies are 6.5 wide all round.  i thought they were all like that.  might have to have a look again.  N/A's have 4 studs instead of 5 so they wouldnt be that.
Perhaps 7.5 inch wide are Series 2 rims.
i have two.
lemme know.
This should be in the Wanted To Buy section mate.
Yeah sorry about posting here, I thought this was the place for Victorian stuff.
Just sent an email to your hotmail.
Thanks
Pat
  • 4 weeks later...
i have a full set of 300zx rims, willing to seperate for the right price. Let me know if you are interested. they are 16inch, 5 stud, not sure about the width and offset, but can check if you want.
Please check and get back to me.
If they are 16 7.5/45 offset they are right.
ha. you're in luck.
I tried measuring with a tape, but that got me all confused cos i didn't know where to measure from. Then i loked for writing on the inside of the wheels and found......16X7(1/2) JJ 45
looks like i've got what you are after.
ha. you're in luck.
Very good.
Just pm me a contact number and we can take it from there
Thanks
They must be stamped 16/7.5 45 offset.
I think you are confusing R33/S15 wheels with the old 300ZX rims.
Also I just checked both (I have a set of both) and neither have any measurements stamped on them inside or out).
On my car the fronts are 16/6.5 and the rears are 16/7.5 and this is definetely stamped on the inside spokes.
I'm not sure what car the 7.5's came from but all I know is that they look identical to the front 6.5's..
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
