I just went to http://www.onlineconversion.com/power.htm to convert Hp to Kw but there are 4 different types of Hp and was wondering which I should use.
1 international
2 metric
3 water (prob not)
4 electric (prob not)
Thanx to anyone who can help:cheers:
https://www.sau.com.au/forums/topic/66508-horsepower-to-kilowatts/
