well i have an R32 GTR and i want to try and find a set of brembo callipars to fit any ideas where to start looking, or should the original callipars be fine. i think the v-spec came out with them but otherwise i need them from a later model. does any one know it they fit straight on or will some changes need to be made?
https://www.sau.com.au/forums/topic/66515-r32-brembos/
Yeah I would be looking at other options, to me the brembos are expensive for their size. Have a look for used 6 piston ones instead if you reallyh need bigger brakes.
But you probably dont need bigger ones, jus get good brakes and great fluid
https://www.sau.com.au/forums/topic/66515-r32-brembos/#findComment-1239694
Unless you are doing regular track days they expensive rice but having said that I can get you some reconditioned for about $2500
no offence to whoever your supplier is, but that is exactly why people should not buy GTR brembos.
I paid $1500 for mine and it hurt, but I had no choice due to racing class rules.
For $2500 you can get the 6 spot porsche brembos on the same disc as the gtr brembos.
https://www.sau.com.au/forums/topic/66515-r32-brembos/#findComment-1241459
2,5k, i agree is a rip.
The 6-spotter Porka Brembo's retail @ ~$800 per calliper. And they are double the size of the GTR brembo, and piston size is very large
So thats $1600... plus fitting and a two piece rotor and your around 2.5/2.7k which is far better value if your spending that much
https://www.sau.com.au/forums/topic/66515-r32-brembos/#findComment-1243613
Ok a question concerning the 6 piston calipers though.:D
The pistons are different sizes front to rear, correct:)
The pistons are sized this way so that when travelling forward the pad is forced evenly onto the the rotor.
Now if i look at a Porsche, the brake caliper is on the rear (door side) of the rotor with bleed nipples obviously facing upwards.
So now if you want to put the same 6 pot Porsche caliper on a Nissan, the staged pistons sizes are going to be the wrong way around, as you will need to swap the LHS & RHS side calipers so that you can bleed them correctly.
OR, is it a matter of swapping the bleed lines and fluid line around so that it all works?
That plus talking to places the axial mount on the POrsche 6 pot caliper makes them a pain in the ass to mount on anything but a Porsche:( it can be done like anything, but i still need some convincing that this avenue is the way to go?!?!?!?!?!
https://www.sau.com.au/forums/topic/66515-r32-brembos/#findComment-1267034
Where can I get my hands on these 6 pot Porsche Calipers? Can anyone point me in the direction of who might sell them?
PM me please!
Any advice appreciated!
get out your yellow pages
And right your nearest Porsche Dealiership.
If not, ring interstate. You wont be able to get em anywhere else
https://www.sau.com.au/forums/topic/66515-r32-brembos/#findComment-1267285
And one more thing. From a bit of reading i have been doing of late...am i right in saying that typically you can use a good qulaity 4 pot caliper up to 355mm in rotor diameter, but typically 343mm is seen as the biggest rotor you run with a 4 pot caliper?
Any bigger and the caliper pistons are nto in the ideal position relative to the rotor and their ability to force the pad onto the rotor is compromised. So typically if you want to go bigger then a 343mm rotor then you need to start looking at 6 piston calipers?!?!
And vice versa, if you have a 324mm rotor, then most 6 piston calipers wont saddle the rotor properly and the the pad contact patch wont be quite right?!?!
Is this correct? As a rule of when you need to consider calipers, its more a rotor diameter thing then wanting to stop any better?
https://www.sau.com.au/forums/topic/66515-r32-brembos/#findComment-1267474
  • 3 weeks later...
I checked out some 6 pot Porka calipers today. On a Skyline the pistons are going to be around the wron way.
Porsche have them so that the small pistons lead, with trailing larger diam pistons. So the only way to orientate them on a Skyline so that the pistns can do their thing and maxise pad wear/force is to swap the fluid/bleed lines around...but i was not able to confirm whether the internal galleries are symmetrical and this can be easily done.
It appears the Posche 6 pots wont work properly, so looking at a CSC 343mm setup next week, escaping that i may have to go to 6 pot APs as the 4 pot APs dont take a 32m thick rotor, only 28mm thick :)
https://www.sau.com.au/forums/topic/66515-r32-brembos/#findComment-1293767
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
