Hello all.
I'm not sure if this thread belongs here but I didn't know where else to put it.
I have a Magicar 8000 Remote start car alarm system on my 97 Stagea RS4.
The day I took it to Autobarn to get it installed he told me I couldn't have a turbo timer with it.
I was wondering if this is true or not I get the feeling the guy just couldn't be bothered installing my turbo timer for me. He refused to install my RSM and boost gauge.
If it truly can't be done I have an Apexi turbo timer for sale.
Any help would be awesome.
Thanks guys.
Zane.
https://www.sau.com.au/forums/topic/66522-turbo-timer-on-a-remote-start-setup/
Autobarn? Take it to a proper stereo installers and see what they say. It can be done if they can be bothered. Although most alarms have a turbo timer built in. Mine is set for 20mins and I just turn it off with the remote fob whenever I want it to (It has auto-start).
(Interval can be set to any preset, I use 20mins because I can stay inside and let the Forged pistons warm up while I finishing breakfast :) )
that one has a timer on it.
you can use the one you have BUT you wont be able to arm the alarm. a bit of creative wiring can fix this issure BUT you may not be able to remote start the car.
best to use the one that is in the alarm.
He is a lazy one i must say....you can by-pass the turbo timer for this... i took mine to autobarn..i had a 2 way pager alarm remote start one..took 2 hours to install...the electrician was in doubt about the turbo timer at first..but he has managed to by-pass it.
it can be done...just take it somewhere else dude.
it can be done mate, tahts what my installer told me too... he said he had 10 yrs experience, and told me that both turbo timers and remote start cant go hand in hand. i figured a way through it. first valet the car, that means leave the car running while u take out the keys, then arm the alarm, then shut off the car with the remote start feature, once u do this, the turbo timer will take the job and shuts off accordin to the time.. hope it helps.. mine worked
p/s: u have to arm the car first b3fore using the remote to shut the engine off.. coz, once u shut off the car before arming the car, u can only arm the car once the engine stops. and also remember to disable the ignition controlled door locks, if you dont, once the turbo timer is off, the car will disarm again ..
arrgh!
have any of you guys actually put one of these alarms in?
it has the timer feature on it. I have tried in vain to get the alarm to work properly with a timer. the alarm side is fine. its the remote start that will stuff it up.
in the end I told the fellow to use the one that was in it and set it for 3 minutes this was on a 32 gtst.
normal alarms and timers do work. I've done them for the past 15 years.
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
