Hi guys,
As the title suggests...what is the average life span of a twin plate clutch ?
I know there are a lot of factors involved, including the driving style etc....
but how long SHOULD they last ?
is 12-18 months too short a life span for a twin plate clutch ?
I was really set on getting a twin plate to handle the power I was after, but right now I cant justify spending $2.5k to get a twin plate installed if its only going to last 12-18 months.
If they do indeed have such short life spans I think ill go for a super coppermix and hope for the best.
https://www.sau.com.au/forums/topic/66533-life-span-of-multi-plate-clutches/
im going to report moans to the CPB, the clutch protection board.. they care and look after abused clutches :)
i even then shes gone to the lenght of modifying her cluch pedal so its impossible to fully disengage the clutch so its always slipping... EVILLL
hehehe just kiddin moans..
im looking at a twin plate so it would be interesting to see the lifespans of other forum members !
Spill peeps! Spill those proverbial beans! But don't expect anyone to clean them up afterwards. If you're prone to spilling food stuffs, like beans, it might be a good idea to invest in a friend with a dog that likes eating beans. Then cleanliness is only a phone call away.
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
    • Hi all! Looking to relocate the battery to the trunk of an R34 GTT. I want to do it using as many stock GTR components as I can (including the harness protectors from the 34 GTR that run underneath along the chassis to the engine bay). So far I’ve purchased the battery tray from a 33 GTR, as the captive weld nuts are already there just asking to be used. There is also the slight issue of now having to relocate the ABS/TC/Fuel Pump Control ECU, which in GTT’s sits right above where the battery will then sit on the tray. Has anyone already achieved this, and if you have any pics that you wouldn’t mind sharing? It would be great to see how others have done it and where you put them, as there are countless holes in the parcel shelf panel to potentially use. Just trying to get some ideas bounced around, and to help uncover any potential problems I may encounter by  my choice of location. TIA for any help!
    • Brand was ard.   I also threw a brand new battery at it and beefed up the wire from the alternator to battery and added an extra earthing point from the battery
    • Evening all,       I'm replacing some bolts on my RB25 with probolt Australia bolts.       Does anyone know the following, m5 m6 etc 10mm 20mm etc       Coil cover   Cam covers   Plazamaman fuel rail   Front cover (timing cover)   Etc   Any help would be awesome   Or any lists anywhere
