Hi all.
I did my research on this forum but to no avail..so instead i'll just ask you guys.
Just trying to find out if i should upgrade to the Z32 AFM but not too sure if I have the Z32 AFM in my gtst.
my question is --> How do you tell the difference between an R33 AFM from the Z32 AFM ? a friend of mine said the stock R33 AFM has the green stickers on them and the z32 has the red or orange one.
well..if that was the case... my AFM has the orange stickers on them.
Here's the number anyway for all you experts. 22680 31U00 A36608 E60
https://www.sau.com.au/forums/topic/66541-z32-afm-question/
