Ok. Im creating this thread as a means to try and create a link to popular threads within Forced Induction.
Ones that answer a lot of basic questions we see often to keep FI from having a new pages of threads everyday.
If you have a thread post in here, and i shall add it too the list if its good enough.
We are looking for threads with:
-Compared parts
-Before/After's
-Basic questions with nice detailed answers that non-technical people can understand
-Detailed topics, those with a bit mroe detail for the more technical persons.
Cheers - ash
Past \"Hot Topic"\ Sticky Threads
13.4 second 1/4 for your 'stockish' R33. (A how to guide).
Project: 12sec Daily Driver R33 GTS-t
Whats is G-Reddy E-Manage?
Low RPM Stalling Saga in your Skyline - Possibly Sorted
Oil control in RB's for Circuit/Drag/Drift
General Questions Topics
Free Boost Mod
What mods to do first???
DIY 100,000km Service
Upgrading Fuel pump? Dont forget to increase Voltage
$22 Boost Controller
Auto --> Manual Conversion Questions
R33 GTS-t Flat Spot Fix
Mis-Fire under boost?
Fixing a leaking BOV
Backyard Race Fuel
Resetting the Stock ECU
Nissan Patrol Clutch - does it fit my skyline?
Poor Fuel Economy - O2 Sensor
PowerFC Software
PowerFC FAQ
PowerFC DIY Tuning
PowerFC - Road Tune
NISTUNE - All information
Emanage - Everything you need to know
450-500HP turbo, Internal or External Gate?
ECU for my AUTO
ECU for my AUTO #2
ECU for my AUTO #3
z32 AFM Install
z32 AFM Install #2
RB30DET(T) into a GTR
Consult LCD Display
RB25 turbo onto RB20DET - Exactly what is needed
Spark Plugs - Types, Gaps, Duration
Metal Head Gaskets
Intercoolers - Everything from A-Z about them
Engine Bolt-On's and Upgrades
Forged Piston Discussion
RB26 - Dump/Front Pipes
GTR Injectors into RB20
External Wastegate Sizing
Upgraded Fuel pump - Correct voltage is essential
$350 Turbo - 250rwkw (RB25DET)
Manifolds
Front Facing Plenum Install - Full Writeup
Garrett GT30 Thread - Full Writeup
RB26DETT
HKS T04R
HKS T04Z
JUN 2.7ltr Stroker/T04Z
First set of Turbos, many options
300-340rwkw A guide for your RB26
RB25DET
RB25 Dyno Results
HKS 3037 on an RB25
HKS 3040
HKS 3040
RB25 Flat Spot
RB20DET
RB20 - 200rwkw, how too
GT28rs (discopotato)
260rwkw+ RB20 Club
RB20 with RB25 Turbo/Cam Gears - Results
RB20 with RB26 Cams
Before & After
RB25 - Dump pipe
Ex Cam Gear - Before/After
R33 GTS-t SMIC Upgrade to R34 SMIC
Edited by PranK
Updating with current links.
  • Like 1
https://www.sau.com.au/forums/topic/66556-forced-induction-quick-ref-guide/
  • 1 year later...
Bloody brilliant idea.
What about some guides (or links to posts) about what is needed for turbo upgrades.
Like the steps required?
I've been searching and there's bits and pieces but no actual simple guide on what's required and when.
Edited by QBall-Cairns
  • 6 months later...
  • 3 months later...
  • 2 months later...
  • 8 months later...
  • 2 months later...
  • 1 month later...
  • 2 months later...
  • 1 month later...
awesome thread, i havent read through it all, but would it be helpful if there was like a glossary type thing, because i dont know all the technical terms nor which turbo is better than which etc and the differences between them? thanks
  • 2 years later...
  • 6 months later...
    • If it's for a SR20, make sure it's not the American Poncams, might as well call them Poocams. Had a set in a friend's car, all scuffed up after a few track days. Like the metallurgy Tomei USA used is junk. Went back to JDM OG Tomei Poncams, no issues till now.   Tomei USA is not the real OG Tomei.   Random rant over, fk the US of A, bunch of c u n t s.
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
    • Unfortunately, not only is that not the case, one of the main "Selling points" of safety over comms is they clearly state in writing that there's no need to segregate safety networks from non-safety networks. It always gets intermingled with everything else on an ICS/OT network.
    • Hello. I have an a31 cefiro but since I am in Turkey we have a CA20S engine. I did some research. Then I found that I can swap with a ca18 but when I heard that it has the similar substructure as the s13. I thought I can swap with an sr20 because the sr20 was used with the s13. So can I easily swap the sr20 on my cefiro or is it difficult?
