I've noticed that there are a few of you on here that play guitar so I thought I'd share with you my plans for my new guitar that I'm about to embark on building. Here is my dodgy photoshop of what it should end up looking like:
I currently own an Ibanez RG guitar (had it for 10 years) and love it. I was looking at buying a second one as my band is about to start looking for gigs and I want to have a backup guitar for this. I figured that I don't have the cash to buy a decent one so I'll build it.
I should have a neck coming this week that I've purchased. My Dad's going to cut and route the body, and I'll gradually piece it together when I find bargins for each component needed.
It's going to be called Project GT-R due to the paint choice for the guitar, and so I can combine my car interest and my music interest. Carbon fibre might be used for a couple of other things as well.
Hope it's sort of interesting even for you guys who aren't muso's or not really in to guitar music.
:band:
I'd like to build a guitar but I'm quite likely to stuff it up completely.
A fixed bridge would be easier and cheaper though. I also hate floating trem but you might love it.
Hope it works out for you.
Yeah it's probably going to take a while to build due to funds etc. I'm planning to be able to get a decent piece of timber for the body probably late next month and cut it out, route out the cavities, etc and then slowly get the electronics and other hardware together when there's a bargin to be had.
Also searching for someone to make a carbon fibre pickguard, etc. That may be hard and pretty expensive, so I might have to cheap out there and just get the plastic items and maybe cover them in carbon fibre contact or something.
I just build a drum set. when i say build i mean bought. it's fun to bash, but i have no idea what i'm doing. might get a book or something.
Very cool guitar though. should make a heap and call them Phantom specials
Ha ha, nah just need to get endorsed by a company and be paid to have them built for me!
Drums are fun, I got a dodgy kit that I'm looking after for a friend. We use it for band practice cause then our drummer doesn't have to cart his around every week but it's a hunk of crap!
Re the carbon fibre pickgaurd - LTSJayce has the name of a guy who might be interseted in a one off peice of work. He recently did a top job on a CF Battery box for Jayces weapon.
He might do a one off.
R
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
