Because you all love me so so much, who would like the honour of providing my with a gearbox.
Doesn't have to be a whole gearbox, I'd be happy with just third gear. You can even have a piece of my third gear as a souvenir when I finish getting all the bits out.
Ok seriously, should I go another 'box or just rebuild this one?
From what I can tell it's just third as every other gear engages but you can put it in third with the clutch out and engine running and nothing happens.
For future reference, when you change gear and the box let's go... it's loud.:kick:
https://www.sau.com.au/forums/topic/66568-so-who-wants-to-donate-a-gearbox/
didn't anybody tell you triple's destroy gearboxes ?
Anyhow, just get a gearbox out of a 33 GTR, they are stronger anyhow.. and cheap - cheaper than the GTS-T boxes often.
OS giken gearset.. you know you are rich..
Taking the the teeth off 3rd usually comes down to torque, it just rips the teeth right off. Although you can get a chipped tooth multiplier, if you have a synchro problem. How much power are we talking here? And what sort of tyres?
:D
Near new 245x45x17 Bridgestones on the front and Nankang NS-1 245X45x17 that were less than 48 hours old fitted to the back.
Car is making approx 210kw at all four (208.3 if we want to get picky) and I had not flat shifted or gone to redline when it died. I selected third, it slotted in, the clutch was released then, bang.
I started the car yesterday to show someone the noise and it had stopped so I'm guessing all the bits have settled in the bottom of the box somewhere.
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
