Hey guys & gals.........have finally tracked down a suiting ceffie and should hopefully be in my hands within a month. (As long as all things go well once it gets here) :wassup:
Now i am trying find out the true width and length of the A31 Cefiro 88'. I have found some sites with listings but they seem a little off. I am trying to measure up if the beast will fit in the garage. If anyone could confirm or inform of the correct dimensions it would be greatly appreciated.
The dimensions i have found are 1486cm-width & 4760cm-length
Firstly the width seems a little 'skinny' and length seems approx correct. I dont have much room to spare in the garage as it is a little one and am looking @ dimensions of approx 4900cm-length and 2500cm-width.
As you can tell not much room to spare so if anyone has a spare 5 min, a tape measure, it would be greatly appreciated. Or alternatively if anyone has official dimesions...that would be awesome to!!!!
Cheers :D
https://www.sau.com.au/forums/topic/66579-a31-cefiro-body-dimensions/
It will fit no worrys. Im not going to go out and get a tape measure, but it will fit.
Your just maybe going to have to be a bit careful getting in and out of the car, more so if you have a passenger.
AHAHAHA well hey a little persuasion gets you a long way!! :wassup: :rant: I think i may have to move some shelving in it but all should be good. Well all things going well, it will be another Ceffie hitting the North Shore :headspin:
