Grabed a copy of HPI the other and just wondering if anybody has seen the car since the kit and paint has been applied. I no the magazines are normally a bit delayed in the progress.
Any pics would be great.
I think the colour they have chosen really suits the 4 door shape, they just need some crazy deep dish.
Thanks,
https://www.sau.com.au/forums/topic/66587-hpi-4-door/
