hey guys, i still havent got my suspension problems sorted out yet
problem: car skips around on small bumps when going straight and oversteers alot in corners with light throttle
i thought it was the rear shocks but took it to pedders and they said the shocks were fine??
i've got stock shocks and stock springs and i cant think of what other reason it could be?
btw, my question is whether a pedders check is accurate? he said the shocks were fine but i dont know if he's right as the back end skips like crazy on bumps on the road. i can also feel that the back is alot harder than before.
i've done 4 wheel alignments so far from different places and still havent fixed the problem
taking it to a suspension specialist tomorrow to see if they can get it sorted.
If pedders are saying nothings wrong, thens theres a fair chance there isnt. If there is something wrong, then Id get a 2nd oppinion.
Out of interest, whats your tyre pressure like?
went to heasmans steering today
found out that the rear right spring wasnt sitting in the mount properly (180 degrees other way) and thus raised the right rear side by about 1.5 cm.
its amazing how no one else saw this when checking the car..
anyways, he said it could be the reason for the "roll oversteering" problem i have
getting it fixed tomorrow and hopefully will be the end of that.
top service over there and they really know their stuff
didnt even charge me today =)
You realise that you can take this further?
When Pedders give you the yellow copy of the report they're saying that the car is roadworthy and that it is safe in their EXPERT opinion.
Disgraceful.
Adrian
Disgraceful.
Adrian
But they didnt rip him off, so its a good start! :)
    • I would hope so. I worry that it also might depend on whether the person working on the claim has had a good day or not. I could imagine that for example modified brakes would be an easy thing to point to for affecting the outcome of an accident. I don't know. I will keep paying my premium and hope for the best. But at the same time keep safe distances, drive defensively and avoid dickhead P-platers in lifted utes
    • I was just working on the assumption that a cammed V8 is significantly less polluty than a Japanese I6 turbo was at the way they tested it in an IM240. Perhaps I'm wrong! Perhaps cutting one of the readings I got in half is a tall order. I don't know too many people who actually got their cars emission tested with a RB to really compare the data.
    • I thought it was just if “the modification effected/caused the incident”
    • Ok, good to know. I have open loop I think, I forgot which ones which but I am running the o2 sensor, brand new and I got a new boost solenoid because my last one was faulty and overboosting by a lot, but it's still technically overboosting. Haven't really bothered to hunt it down as I don't send it hard regularly.
    • You should not be able to see much smoke behind you if the mixtures are good - for ~13-14 psi anyway. It's not like you need to be running hell rich for only that much boost/load. Your tune might be a tad too rich. The tuner might have done that because they like to run a lot of timing. It's impossible to know what's going on from here. It won't be the actuator. It won't be the MAP sensor. Regardless of if by "MAP sensor" you mean either the Neo ECU's boost sensor (which is literally only that, a boost sensor so that the ECU knows a) that it's achieving boost, and b) that it is not overboosting) or you mean the dash gauge's MAP sensor (because it can't have any effect at all), or you mean the boost controller's MAP sensor (because it is very unlikely that it is running in closed loop, and so it is effectively just used to know when the pressure goes positive and so you can see the boost on the display, for the most part).
