Hey ppl, i got some issues with the speedo in my ceffy. It seems to be out by aroung 20 km/h at 100, like i'm doin 100 but it says im doin 120. it seems to get progressivly further out, like at 60 it says im doin 70 and at 160, well the speedo is off the clock, and the speed limiter still hasn't cut in. at first i thought i had a lower diff ratio, but that doesn't explain the different variations. Also when I accelerate slowly the needle goes round smooth, but if i boot it the needle jumps 20 km/h at a time, like from 140 straight to 160. Anyone have any ideas???
https://www.sau.com.au/forums/topic/66617-speedo-problems/
same problem here... (also the km readings are higher by around 20%, ie. clocks 1.2kms every 1km i travel... :D will be - factor when i sell the car)
in my case, the problem most definately is the small tyres that came with the car as my mechanical-minded friend told me (read sky80y) ;) the tyres on the car atm are 195/55/15s... i'm getting 205/60/15s soon...
https://www.sau.com.au/forums/topic/66617-speedo-problems/#findComment-1239750
I think your needle is toast, I replaced my speedo because that happened to me, I have an aftermarket diff and 18"s on mine and my new speedo is only 5km/h out. When im doing 100 speedo reads 95. I got that information courtesy of a dyno
https://www.sau.com.au/forums/topic/66617-speedo-problems/#findComment-1239773
205/60/15 are what i run, i thought my tires were to big, but if they were too big i'd be goin faster than what my speedy said, just on a side note, nissaner, do you go to the off street drift at oran park?
hmm... maybe the problem wasn't my tyres...
and no i'm yet to goto those drift meets in my ceffy... public streets are challenging enough for novice drivers like myself... :D
https://www.sau.com.au/forums/topic/66617-speedo-problems/#findComment-1239890
I have been told also that they Ceffys have a common fault with Speedo cables breaking as I have been through 2 so far. ( have a few (4) coming from jap in the next container)
Also the sensor in the G/box has been know to do the jumpy thing in speed as it does it with my ARC-R
Will follow this up when it all arrives
https://www.sau.com.au/forums/topic/66617-speedo-problems/#findComment-1240503
my cef does the same thing with the speedo, i.e doin 100km/h on speedo but only doing 85km/h on the road. But mine has stock size rims/tires, i.e 195/60 15in. But i have a locked diff aftermarket manual conversion.
By the sounds of it this is a common problem.
David
https://www.sau.com.au/forums/topic/66617-speedo-problems/#findComment-1252448
My speedo is consistantly 10% higher than what I'm actually doing, I base this on the speed reported by my Impakt DigiDash (takes it's data from the diagnostic port) and other traffic.
The needle also "floats" if you know what i mean, it just doesn't seem to move right and wobbles a bit back and forth from time to time, I have a feeling it might be the cable where it hooks up the back or gearbox isn't quite right but have yet to check it out.
https://www.sau.com.au/forums/topic/66617-speedo-problems/#findComment-1253545
I seem to be having the same problem with my cheffy. I just picked it up at Freo port today an it seems to be out around 10-15km at 60km/h. I know it has been converted from auto to manual, maybe they didnt get the manual sheepo cord.?
that is all I can think it might be as putting on bigger rims shouldnt change affect the speedo that much.
https://www.sau.com.au/forums/topic/66617-speedo-problems/#findComment-1277373
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
    • Yup but for me its the HR ! Cut my teeth on the old holden 6s in the day ! And here's me thinking in the day it was also the 300ZX and the Mitsubishi GT3000 ! All, as well had good lines, but always seemed to need finishing off, style wise.
