If anyone's headlights are stuffing up ... like mine are .... try checking the actual switch on the dashboard.
I found that if my headlight goes out, and I tap the switch, the light comes back on again.
This made me a little happier as now I know where the problem lies.
Hope this helps someone else too!!
https://www.sau.com.au/forums/topic/6664-headlight-prob-solvered/
Yeah it's the left headlight.
I tried hitting it the light but that didnt work, so I hit the switch instead hahaha:bahaha:
It worked though!
Must be a dodgy connection in there!
BTW : Driver I saw you yesterday ... your zorst sounds nice :)
This is amazing, i had a problem with my front left headlight and thinking it was just 1 of those niggling little things with a 7yr old car i just gave it a whack for the 3 or 4 times that it stopped working. The last time i whacked it i must have done it some good coz it hasn't stuffed up since.
Then i come on here and its a common problem.
SAU rocks.
:P
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
