Just finished replacing Turbo/HKS Exh. +3"Dump/CAT/Headwork/HKS HGasket/P&P etc. NOW find on Dynoing, its got a bad knocking noise over 3000RPM. :cheers:
Has been off the road 12 mths so driving around keeping the Auto in O/D to keep revs under 3000. (Stalls 2800)
Hell I have to get some K's on it after all this time.
Even though its got 550cc RX7 inj's its running very well with my double flow AFM Mod compensating but a bit on the rich side at revs.
Sounds like its coming from the top of the cams at rear cylinder.
This WAS the cylinder that the H/Gasket blew through to the water jacket after coroding though as I was on the fourth run of the night at Calder drags.
Have I hydrolocked it and stuffed the bottom end somewhere?
Bearings etc probably took a lot of water in the oil also before I realised.
Also the oil pressure is only reading 2 on the gauge most of the time but it always has and was told by others that is common on GTS??
DAMN, I can feel the power potential as its much better than before when it Dyno'd at 160RWK even now running a bit rich and way out of tune on only 10PSI!! :wassup:
How long before it goes BANG and I need to do ....... WHAT?!?
1. Replace bottom end components with parts from NA RB20 I have.
Cheapest option :rofl: But who could do this AWD eng out in Melb at reasonable cost?
2. Replace BE with GTR Crank/rods/Pistons to fit = 2.4?
3. Replace everything with a stock Stagea RB25 (to suit AWD)
I have put a lot of money and time and sweat into this thing and really want to be a Troy and persevere with the RB20. :Oops:
Sorry for the long post but its got me screwed :mad: at the moment..
https://www.sau.com.au/forums/topic/66642-help-bad-knock-in-rb20-3k-rpm/
