ECU problem :(
romeo
 Share
HI guys
Iam in desperate need of help.
I got a NA r34 rb25de NEO
Basically last few weeks the check engine was coming on
So i took it to several places, where they ran diagnostic, everyone gave me different answers.
N e way i decided to take it to Unique Auto Sports, great guys there. Now they ran a diagnostics, they first thought it was the Crank Angle Sensor. Fair enough, i ordered a BRAND NEW CAS from japan for $680. Got it replaced(labour;$80), but the issue still remained. Took it to Unique Auto Sports again, the ran thru testing the whole day, but couldnt find the problem . In the end they gave me sure possibility thats its the ECU. OK so i payed them $680 for labour and iam still where i started from. In the end the CAS wasnt the problem. So there goes my $680. Also cyclinders 4 and 5 dont always work, and the car is rough(sounds like a rexy). They say is the ECU thats at cause or sending bad signals. They did all test possible and everything else was ok.
Now they recommended i get a computer from another NA R34 and test it on mine. Unique Auto are willing to do the swap and test for free. So guys all iam asking is for a helping hand for someone to let me use thier ECU on my car to see if my ECU is at fault, thats all. Iam even willing to compensate a little for all your troubles. Please i really need your HELP!
MANY THANKS!!!!!!!
i took my car to Unique Auto Sports, my car was running shit as...they assured me it was the coil packs even offered them to me for $900, wow so cheap. Anyway i bought em my self for $600. It didnt even touch my problem, so $600 dollars later + there dyno fee i was left with nothing...
I found the problem, guess what it was, one of the knock sensor plugs wasnt plugged in, how much did that cost me??? NOTHING!!!!!!!!
THANKS HEAPS GUYS!!!!!!
Seriously dude, search on here for ure problem u may be suprised at wat u find. Its wat i should have done first and saved a shit load of money...
They sound like bad mechanics to me.
Just substituting parts that they guessed were the fault. (Like a backyarder mech)
A real mech, could throw it up on the scope and check the sensor without just guessing.
Same with the rest of it.
Have they thouroughly checked the wiring loom?
Unusual for an ecu to shit itself.
Sounds like they are really guessing and have no idea to me.
Start checking your coil packs, spark plugs and injector plugs. The coils and injectors may bring on the light. They will cause a rough REX idle also. If you pull out all the plugs you should be able to see what's going on. Plugs are like a book, they can tell you the whole story.
ok well this is just my experiance with vehicle electrical systems being in the trade and all
time and time again we do so many diagnostic checks on cars that customers bring in sayin what is wrong with it and what not we do our checks on a vehicle that is appearing to run ok. Now you have two choices to make send the car out after charging a small fee for you time and make them aware that no apparent fault was found BUT and i make this BUT very clear you vehicle may break down so that fault can not be blamed back on us . we also say the minute its giving trouble to bring it straight in so we can get a clear understanding of the problem because when a customer says my car is runnin rough it can mean many things,electrical,mechanical or fuel system roughness just because its fuel injected doesnt neccessarily make it a deffinet electrical problem
Now the second option we can take is contact customer give them your previous problems you have had with that model car and suggest that we can replace possible problem or regular faulting parts but cannot guarantee that will fix the problem
so i beleive what UAS did was listen to the symptons go on previous jobs done and replace what i could be
now with you vehicle could be a number of things :
wiring - including plugs to injectors,coil packs,igniter if you have one a dodgy terminal can cause a shit load of searching for!!
individual coils??
this business is a difficult one to locate problems in electric/electronics
and with many jobs we have done too the customer has to wear the cost of previous parts fitted it is just this trade makes problem finding difficult because ecus have a mind of there own when the play up and dont play up
also half the ecu diagnoses crap that the ecu puts its is not even relevant to the problem so i dunno
that is just my two cents worth may piss u off but thats just how i see your dilema
Thank you guys for all your input.
Unique Auto did all the checks under books as they said. Put it this way, i gave them the car at 930am and i left with the car at 530pm. I was there the whole day, thinking it would only take a few hours tops. Im not too mechanically minded, but i know they changed the spark plugs they tested the coils, they checked voltage on the signals, wiring and so forth. They did vigourous testing as i saw it, but then again who knows.
Thanks guys i really do appreciate your opinions and ideas. Im not sure if this issue is a serious or just a minor.
Any ideas what else i can do, where i can go. How bout the ECU testing part, is it worth testing with another 1. If one of you guys can lend me a hand.
THanks again!
ECU fault finding is like tip of an iceberg cos it only gives you an idea of that it really is
take ignition singal fault for example. if it detects any misses in current to any of the coil packs it would be the coils or the transistors to the coils, something not adding up right and the ECU will flag it
as far as CAS goes. if it doesnt work the car wont run. basically its as simple as that, it has an optic sensor inside with a disc with small slits in it that spins heaps fast. they get too hot and start to crack etc and then they just die. then the car doesn't even run at all cos it doesn't get the right signals - so you know when they go.
putting voltmeter/cro on it and then working tracing out the problem is the only way to diagnose. swapping parts is just guessing. i wouldnt pay someone unless they actually fixed the problem
yes you are right, i should have only paid for a working solution to the problem. Thats my bad, which ill remember in the future. Just out of curiousity, is there any legal issues regarding this type of service. Like i said, $680 was paid for part which didnt need replacing, also labour cost which dint fix anything.
Now the ECU was giving a Primary ignition signal error, hope that helps also.
THANKS!!!!
i doubht u could do anything about the money legally, just cop it on the chin and learn from it...
i have another dodgy story about UAS but i'll leave to myself, im sure they are good mechanics they prob just thought i looked like a sucker and took my cash...
Just an insight on the problem.
In the morning the car starts normal after about a minute, the engine light comes on. But the car still runs fine. After driving for 2 - 3min the car starts running rough, sounds like a rexy. From what the mechanics told me that is because the car is not running on all six's. They did test to prove that.
Any way after driving for a further 5 - 10min the car starts running normal again, and also sounds and drives normal. Though the engine light still remains on. Same error Primary ignition signal.
Mayb this clears up a few doubts or makes the understanding a more clear
THANKS PPL!!!!
btw the feedback you guys are giving is really appreciating, more than i could have asked for. :D. Also im from SYD
i know exactley how you feel...
its like they are doing guess work, oh well we must both look like rich suckers...haha
but seriously if you are ever gonna dyno your car or do stuff with the ecu i cant recommend enough Adam @ J.E.M. (Just Engine Management). He pointed me in the right direction with my car, i took his advice and i fixed the problem 2 days later...
Yea i feel real shyt about it, i would have paid 1000 if the issue was resolved honest. It just feels liek my hard earned bucks went no where, im back where i started with $1300+ short in my pocket
Is this place in SYD, any contact details?
hey just reading your post romeo if you are getting a code fault for signal to coil packs it sound like you possibly may have a broken wire in the harness that go to the coils it gets real hot in there and electrical wires perrish . the other thing is bad connection to coils or coil pack insulation is leaking spark to test this remove plastic cover get a piece of wire and connect one end to battery negative and strip other end to bear wire aprox 10mm back and run it around the coil insulation while engine running you will see a spark jump and it may drop a cylinder when spark tracs to wire if this happens its a bad coil replace it.Also do you not have nissan agent in aust. they should be your best bet as they will have factory san tool which will tell them alot more information unlike ob2 scan tools they are only a guide and very common to local mechanics hope this helps you as i dont think its your ecu unless you have shorted or something you havent had welding done on it with the battery connected this is a good ecu killer good luck
unreal.....Do an onboard check to decode the ECU...then find out the relevent code and backprobe the loom to check the circuit....get your hands on a wiring diagram....If you dont want to spend anymore money,decode it first then post back hear your findings and i will see what i can chase up in the way of wiring...to decode it locate the small plastic door underneath the steering column,inside you will see a connector stuck to the other side of it...take a digi pic of the plug and post it up and i will circle the wires which you need to bridge out to extract the code
rainster i think ur theory may be correct
cause in the morning when it starts, everything seems kool, then after a while it keeps sounding in and out like a wrex, then after a lil longer it stays sounding like 1.
Il surely take that on board.
Thank you guys... !!!!
 Share
    • A stand alone boost controller will not give you the control you need, unlike a modern ECU. Your boost will always naturally target the wastegate's opening pressure first, your controller then will allow you to add more boost as required.
    • I recently discovered that I could not remove the outer bolt on one of my rear UCAs. Looked like it was seized to the crush tube. It wasn't all that long since I had last had that arm out (I dunno exactly, but certainly <2 yrs), so I was a bit surprised. I thought I had stock bushes in the rear knuckles, so I ordered some new PU bushes and resigned myself to having to do some dismantlery....and some butchery. It was clear that the seized bush was going to need to have the bolt cut out of it and then possibly some more brutality after that. Upon getting the 3x arms on each side disconnected from the knuckles (with the exception of the seized one, of course), I discovered that I had in fact put PU bushes into the knuckles when I did the subframe conversion about 12-13 years ago. So, I say "Oh, good, I might not have to swap any of these others out". We set to work butchering the bolt out of the seized arm. Stainless blade in a big-arse Milwaukee recipro made short work of it, and also damaged the arm, which added a welding and grinding and painting step to the whole exercise. During the butchery it became clear that the bolt was not just seized but bent. Head scratching ensued, as it is hard to understand how that bolt could get bent. I did suffer a broken (stock) toe control arm on that side a few months ago, and drove some miles with some significant rear wheel self steer and lack of control, which probably was the cause. But it's still hard to understand how it would bend that bolt, rather than just bend the arm. But here's the start of the real discoveries. The crush tube was rusty as all shit. I mean seriously rusty. A little on the inside, contributing to the tube seizing to the bolt (along with the bend). But the outside had at least 2-3mm of compressed flaky iron oxide jammed in between the parent metal and the PU bush. This one was brutalised and still took some effort to get the PU off the crush tube. So I thought I'd inspect the others more closely. The one on the tension rod adjacent the bent one was first. I had to use a 2-jaw puller to get the crush tube out, and it took some effort. It came out looking like the first one. All 6 of them were the same, except for one that looked not too bad. Had some corrosion on it, but was mostly OK. There was also a significant amount of corrosion on the inner surfaces of the knuckles. They took some convincing with pointy tools to let go their grip on the inside of the holes they were in. There was no sign of the original (SuperPro) lube anywhere. I and my bro-in-law have never seen any crush tube end up looking like this. It was seriously like the car has spent time putting boats into the water at the boat ramp. So, it seems like the PU might have been bonded to the steel on both sides, which would have to make them work more like stock rubber bushes (where arm deflection results in twist inside the rubber). Despite this, I have never had cause to believe that they were so tightly bound up. The suspension moved up and down much as you'd expect. The car never made any noises in those bushes that would have led me to believe there was a problem. Maybe the rusty interfaces actually were "sliding". Anyway, lesson learnt. Even quiet, non-troublesome PU bushes should be inspected every now and then!
    • the boost controller allows you to adjust the opening of the wastegate (which only has one preset spring) I'm going to see how it acts on it
    • I studied the principle of wastegate to begin with. so if I understood correctly. the moment when the turbo "spool" is where the boost control begins. When the target level of "psi" is reached the wastegate opens to regulate the exhaust pressure passing through the turbo and thus control its speed and the rate of boost
    • Right.  I'll try my best at a concise "bring you up to speed" on stuff that may be missing here - obviously open to questions or further input from others as relevant. Here's a datalog from a responsive turbo setup with electronic boost control being used a bit, to keep it simple I've marked 3 points of interest.  All of these charts are on the same time scale on the X-axis, so you can reference what engine rpm is doing in the top graph, boost and EMAP (exhaust backpressure) in the second graph, and turbo rpm in the bottom graph. A) The turbo gets it's power from exhaust gas, and pumping air takes work.  As a result you can't just spin a turbo with a fixed amount of exhaust energy and expect it to keep spooling - the bigger the turbo (ie, the more air it can push) the more exhaust energy you need to drive it.   The most obvious ways of getting more exhaust energy are by adding displacement, adding boost, or adding rpm - but as you add any of these the turbo also needs to do a bit more work so there is a big balance of these things needed to even get to your target boost and sometimes that's not even possible. What you can see in step "A" is that there isn't enough engine rpm or boost to reach the level we want, so this is where "lag" is.  The dyno run continues and rpm increases, which gives enough energy to increase boost, which helps spool  the turbine speed up even more - so you can see that the rate that the boost (and turbo speed) are starting to ramp up faster than the engine rpm is, so turbo is really starting to wake up as the graph gets closer to point B....   B) At this point we've been able to reach the boost that is actually desired at this point.   To stop the boost from going further than this the wastegate will open and bypass gas past the turbine, meaning it doesn't continue accelerating at the point it was before but instead carry on at a more progressive rate which matches what the engine needs.   The wastegate will have a spring in it which is rated to a specific pressure where it will start bypassing, but electronic boost control (managed by the ECU) can adjust how much pressure the spring sees in order to allow some tunability on how much boost the wastegate actually sees, and therefore how much exhaust it bypasses.   The tune in this case stops boost from ramping up HARD at around 21-22psi just before 4000rpm, then as the rpm continue it allows boost to continue up to around 25psi higher in the rpm.   You can see the turbo speed fairly steadily increases through the rpm to ensure it's keeping up with the increasing airflow demand due to the engine speed being higher and boost being pretty steady.   If the boost dropped off after a point then you may see the turbo speed level off or even drop.   C) You can see that despite the boost pressure staying pretty flat here, the exhaust pressure is steadily increasing and at this stage has overtaken boost pressure.   This isn't unusual, and is largely as a result of the increasing energy needed by the turbo to pump more and more air to suit the needs of the engine as it revs out further.   There are a bunch of variables in regards to how much back pressure there will be on a given turbo etc, but its one of the factors we manage when sizing and tuning a turbo setup.   When exhaust back pressure starts exceeding boost pressure you will eventually start seeing signs that the turbo is running out, the engine gets less keen to make more power and it gets harder to raise boost further. In this case it's a fairly acceptable compromise for the power level (around 630kw on a 3litre engine with full boost by 4000rpm), but you'd not want to push it a lot harder than this.  The maximum speed rated for the compressor wheel on this setup is around 125,000rpm so you can see its starting to get close on that side as well - I feel like this kind of illustrates some of the turbo related things we both decide on how far to push, and are also limited to how far we can push depending on the parts combination. Hope this helps more than it confuses things
