hey guys im stuck big time
ive got a 32 gtr, avcr, exhaust, and filters.
with the avcr, it spikes like a fking cactus, i have 2 settings, .7 bar, and .9 bar. Both never drop below .9 bar, but in the menus it says .7 for A and .9 for B... wtf? neways the major problem is the fact that im getting .9 in 3rd 4th and 5th, but in 1st it ranges from 1.2 bar right up to 1.49 bar being the highest i have seen......yes it fkn scared me too as far as i know i have stock turbos.
so does ne1 know what i can do with it ?? is there any settings, duty cycles, gear judge, nething at all that u guys know of that i can use to correct it ?
any help at all would be great thanks every1, if any1 has a gtr and using an avcr, can u please pm me that would be great !
thanks in advance
steve
https://www.sau.com.au/forums/topic/66656-big-problemavcr-spiking/
hi mate,
If you turn the AVCR off (as in not setting A or B) what does it read? my understanding is it should read 0.7bar (mine does), might prove it is hooked up properly
I also run it with 0.9bar, i will check what my cycles are for you when i get a chance
no, my understanding is it should stop at the factory boost level (.. mine certainly does.. and there is no sign of the original boost actuator in the engine bay (the car came with mine)
hopefully someone here can confirm for you, but it certainly is on mine :D
the way i would think it works is the controller keeps the wastegate open for longer periods of time (to make more boost), when the controller is off, then the normal pressure would apply (which the wastegate is set to 0.7)???
I fyou have the usual breathing mods then you will naturally see a small boost hike. So turn the thing to "Off" ... ti wont blow anything. the car will drive at whatever your lowest boost setting is.
I guess with exhaust etc you could be running as high as 12-13psi , if the restricot has been removed then you will actually be running 1 bar. So its not your AVCR thats spiking.
So lets assuem that with the theing in "off" it reads 0.85bar. You will never be able to run 0.7bar. Its impossible.
So lets say you want your settings to then be 0.90bar (A) and 1.0 bar (B). Set "A" to 0.90bar and duty to about 20. The thing will hold boost and afetr a few hits it will start to learn...which bring me to the next question. Who installed your AVCR? There are two variations on the install. Easiest way to identify is if your injector readins make sense or not. If they look a bit screwy then the thing should self learn a lot quicker.
For "B" set it to 1.0bar and again start duty cylce around 25, if you fall a bit short of makign 1.0bar then try a duty of arounf 28-30.
if your car was an R32 GTST i could tell you how to set it up easy, but id suspect GTR would be a little difference with regards to the duty setting.
But first things first. turn it "off: and give it a good hit in 3rd and 4th gear and see what your peak recall is for boost
The AVC-R is an amazingly powerful EBC, download the manual and read it, many times, from what you are talking about here, ti seems that your Gear based Feedback is set incorrectly and your gear based initial duty cycle is also incorrect.. These are critical elements in tuning your AVC-R properly, I spent some hours and lots of fuel tuning my AVC-R on my 180, tuning on a quiet road (lots of quiet straigh road up here.)
Basically if your feedback setting is too fast or slow in high gears the AVC-R will do one of three things, fluctuate rapidly, drop boost, increase boost. The effect that you get is also dependent on the Duty cyle of the RPM based settings..
Here is the process that I found best to tune my AVC-R: (may or may not work for you)
  1. Set the intended boost pressure at about 0.2 kg/cm above your wastegate actuator level
  2. Using the process from the manual, get the AVC-R into learn mode and drive around until it can hold the boost pretty closely.
  3. Pick a gear to tune the start off with and stick with it (2nd gear is good)
  4. Set the gear based initial duty cycle to a figure where it doesn't spike coming onto boost
  5. Set the gear based feedback to a level where it holds boost through to red line (or theoretical max).. Tuning too high or low will exhibit strange results, this can take some time. This is also a broad range setting so get it as best you can
  6. Adjust the gear based initial duty cycle so that boost comes in as early as possible without any spiking (this is always fun..)
  7. Go back to RPM based duty cycle and iron out the dips and peaks, the AVC-R will actually do this itself in Fuzzy logic mode if you have gear based learning turned on, but it is slow to do so.
  8. Tune the next gear in a similar fashion to above..
  9. After each gear is tuned you will notice that the numbers in the Gear based feedback settings follow a pattern, this is where the speed of your actuator is coming into play..
All of the functions int eh AVC-R are there for a reason, the fuzzy logic has boundaries, some of which I find to be a little restrictive, but considering that the unit needs to be able to go into "anyones" vehicle they have cut it down far enough.. In the cases where the self learning doesn't work quick enough or doesn't adjust far enough, it needs to be helped along the way with some manual intervention..
If you can read and understand the manual and what each function does than the AVC-R is a perfect EBC for you, if you don't understand it, take it somewhere and have it professionally tuned..
    • Reasonably hard, although I haven't run it with the new Endless setup yet. The old brakes were F50's on 335mm rotors and the car did a 1:40.6 at Phillip Island which is a reasonable time, I'm seeing high 600s on the temperature paint. A guy I know ran the Endless fluid at WTAC without issues and he was doing 1:33's I think (Evo) with a 355/332 setup. I don't get out to the track as much as I'd like but we put the car on the hoist and spanner check every bolt and re-paint mark everything, bleed the brakes, change the fuel, check the coolant system and re-bleed blah blah blah before every event. Motorsport is expensive, RB's are expensive so a couple of hours before an event is time well spent. It's also a net time saving because if you can keep your RB from self destructing it saves you time in the long term!
    • Welcome Alice......hope you have a bit more luck from here on! What was done in the build?
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
