Hi, I am about to purchase a set of SARD 550cc injectors from the NenGun Performance soon, do the injectors are straight fit into the RB25 ? Or I need to get the collars for them as well? Does anyone have purchase any SARD 550cc injectors from Nengun performance before? Do you have pay tax? and how much? Thanks
https://www.sau.com.au/forums/topic/66667-sard-550cc-injectors-for-rb25/
That are a "straight fit", but they are a pain in the arse with the collars that you need to use to get em sitting right.
For the extra few $$ get the Nismo 700cc injectors. Straight fit without issues.
i didnt pay tax on my Nismo ones through Nengun, i was lucky.
Thanks for the reply guys. How many kw will the SARD 550cc injectors to be max out? I need something can support 250-300kw at the rear wheels. So 550cc should be enough to handle it? How long normally will take to get your goods from nengun once u paid and place order? Or does any1 have a set wanna for sell in syd?
i got some 550cc injectors shipped form the US for just over $500 all up ..
see http://www.deatschwerks.com/
i got some and they plugged straight in, no fussing, no mess, and running 240rwkw i never see more than 50% duty ....
hell, 660cc are only 470 USD for 6 !!!!
easy choice really
easy choice really
Ditto, but not installed in anything yet!
I got the 550cc yellow top Nismo injectors and they are a direct fit for the stock RB25DET fuel rail. I got them through Nengun but I had to ask for them specifically.
I got the fuel pressure regulator for the odd $150 as well as it was recommended by a few well known workshops.
What is the spray pattern of the of the deatshwerks injectors? Is there one hole or multiple holes?
Tang0: What mods you have done on ur GTST R33 to get 240kw on 13psi?
Thats pitty, should post earlier (but thanks for telling the web site), I just ordered and paid for the SARD 550cc injectors from Nengun. Should receive them in few weeks time. Did you guys pay any GST/tax when you receive the injectors?
Currently, I am putting a GT30 500hp turbo on the GTST R33 with SARD 550cc injectors, Walbro 500hp intank pump, custom manifold, 3inch exhaust, bigger cooler, Either Microtec or Haltec computer. Hvnt decide I should put a regulator (aftermarket) or not. What hp (at the wheels) I should see and on what psi? Is any1 running similar setup that I hv now? How strong are the factory internals?
Cheers
not for the RB25 stock fuel rail.
at least not a few months ago.
700cc's wont make a difference anyhow. They are there if you go for more pwoer later  :D
Yes, Nismo have 550cc injectors for the stock rb25 fuel rail and Nengun sell them. Have been doing so since last year :), trust me i was looking.
Tang0: Thanks for that. I know Dave as well, he is a good tuner !
2BNVS: Did you pay any GST/Tax when you recieved the injectors? So you will need the collars to fit the SARD 550cc injectors (because on the nengun web site, it didnt show any RB25 550cc injectors collar, only on SR20DET)? I think I better email them to remind them to send the collars as well. I dont wanna end up to wait so long.
Cheers
yep u need the collars, when i originally ordered the injectors it said it came with collars but it actually didnt, brent said it was a mix up because the rb25det was the only exception, so i had to buy the collars seperatly which is done now, on the site they should have them, they will be the collars for 63508 injectors which are 550 sards, which also fit s14 and s15 200sx by the way
oh and no i didnt pay any extra tax stuff, ive bought many parts, ecu, avcr, injectors, dash, cam gear and never paid extra...
ben...
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
