try one of the automotive stores..you know which ones..universal fit are usually really loose, probably hard to find some for r33 seats. its always a nice suprise to get a new 2nd hand car with covers to find immaculate seats under them..
https://www.sau.com.au/forums/topic/66672-car-seat-covers/#findComment-1241631
