damn computer woudnt let me post it proporly!  was jsut wanting to know what you guys do for petrol over there as i am made aware you dont have ANY ultime premium really good stuff there...cheers
Nah no 98ron down in tassie any were yet only if u buy it in a 200 liter drum. heard a rumour that we might be getting it by june/july
yep, it is on its way finally. LRP is being phased out atm and once it's all gone 98ron will 'apparently' start coming in. currently I just use octane boost with premium, used to use toluene.
Well LRP has been out of action in Tassie for a while now. It may say LRP on the bowser pump but it aint whats going into the cars. BP use to run there PULP for older cars but was phased out becuase of lead concentrate. Who the hell is going to buy fuel from PA at what they charge for there STi's??? Give me a bit and i'll get the name of a certain some1 that is getting OPTI MAX in!!!!
  • 3 weeks later...
The BP on the highway in hobart have stopped selling LRP so bp ultimate may be at the pump within a couple months I've heard.
Will be interesting to see what price it is. I can't wait to run ultimate so I can get a more aggressive tune. running 170rwkw on RON95 with a very conservative AF ratio.
i work for one of the big fuel distributers in tas and the offical word that we have been told is that ultimate at this stage will not be in tas any time soon. i know its crap coz i would love to have it in my car. but they just told me to get a 200lt drum. nothing we can all do but keep puting pulp and octane booster in.
oh great news :rofl:
living here can suck sometimes.
I wonder how much a 200 Litre drum is?
yeah it can suck
um i dont know how much they are of the top of my head but i can find out in the morning when i go to work but it wont be cheap. if you was going to go that way you would be better off getting some friends that wanted some of it as well and all of you geting one and use the one drum so its not siting around as long.
oh great news :P
You might want to give this guy a call, he supplies to most of the races and he does a pretty good price.
"Race Fuels 102 octane unleaded, CAMS certified, 20L $88, Methanol 200l $220, Pennzoil Race oils in stock, all grades, Moto Sport Distributors, 15 Killafaddy Road LAUNCESTON 03-6339 2770 or 18 Chesterman Street MOONAH 03-62734283."
They also stock Tolulene and can mix it how ever you want, thats where we get all our stuff from
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
