Yeah Mr En. One, you may have not driven it after vip checked it, didn't check the oil, blah blah blah , but fact is that your mate drove it for 300 kms to get it to Devonport and admitted that he heard a noise...I then get it with a stuffed engine....they are the facts...
I agree with you 1400r, his mate broke it so his mate should fix it.
  • Replies 48
well there may have been problems the inspection didn't pickup, the car could have had a problem that could have been exasperated by giving it a good workout.. Any skyline should be able to be driven on redline for a couple of hundred km without a problem, if there was no problem.
To be honest I doubt it wouldn't have been anything you wouldn't have done sometime in the first 6 months of ownership to cause the same end-result. Its just one of those grey areas, and shit happens.
The way I figure with these things, if it was going to happen it was going to happen. It just happened to happen before you got hold of it really, which was a pity. Getting angry at anybody doesn't solve anything, fixing the engine will solve the problem.
The disclaimer on the report says that VIP's report is valid for 3 days only after which it becomes void. The car was inspected on the 17th Feb and the car left Tassie on the 26th February. I do have a reading of the kms from when they inspected and I received the car with about 300 kms more but this may not be enough. The car had also been sitting away in storage for 10 months so when I spoke to the inspector, he said that due to this reason and constant thrashing for 300kms, the car burnt all its oil. I know that they'll try to shift blame in any way but the fact is that they inspected it on the 17th Feb, the inspection is valid till 20th Feb, the car left Tassie on the 26th Feb.
Sorry, it's been a few days since I got back to this thread.
What's this 3 days crap? It's irrelevant anyway. They reckon the oil level was fine when they checked it, good that's exactly what you wanted to hear. Because that means it either had an oil leal, which they should have picked up. Or it used the oil in 300 k's, which again they should have picked up.
Even better, the inspector admitted that he knew it was stored for 10 months, he should have recommended an oil change if there was any doubt that the oil was good. Or if he thought the rings where stuck from no use, he should have warned you. There is no escape for VIP here, you have them by the nuts, start squeezing.
Get your mechanic to write a detailed letter on the engine's problems, attach that and the quote for the repairs to a letter of demand and send it to VIP. The longer you wait the less chance you have of getting some money. Time is not your friend.
Let me know how you get on, I always answer PM's:cheers:
SydneyKid,
I'll get my mechanic to write a report about the engine but I don't know if it will help. VIP will argue that there are some things that cannot be picked up in an inspection and that the previous owner could've given it a hard time after the inspection. VIP said that there was no oil leaks anywhere and Mr En. One confirmed this. What gives me the shits is that if there was a problem with the engine, then the previous owner would've known about it and it would've been nice to let me know. It's just good ethics...
I've read this whole thread and all I can say is that this is :bs!:
George gets the car with a stuffed engine after it was inspected by VIP who said all is good. The only thing that changed after VIP checked it was that it got driven for 300kms to the port!!!
For the record, I didnt drive the car after VIP checked it, didnt check the oil as VIP menttioned no problems with it, sold it for cheap therefore didnt change the tyre, arrived in Sydney with suggested problems... I cannot pinpoint the guilty party myself.
Ahhh, helloo...Mr En. One, your mate is the guilty party. Assuming you didn't drive it after it was inspected, then your mate was the last guy to do so, so I think he is responsible. Stop being a wanker about it and reach into your pocket and fork out some dough for the repairs :)
hmmmm i hate to be rude and state what happens in reality but as i see it you didnt inspect the car yourself so therfore you have to wear it......as far as i am concerned a lot of prepurchase inspections are not even worth wiping your behind with....over the last month or so i have checked various vehicles after one these inspections to only have to tell the owner that there car has had 1/4 panels put on,radiator support panels,back panels all been plug welded with a mig welder and not ground back to an acceptable standard caroliner jaw marks on the sill panels and my grandmother wouldve spotted all this!!!At the end of the day what has happened is bad practice and i am pretty sure its obvious that the guy that drove the car there done it.....but unfortunatly you have to wear it....on another note....theres no way i wouldve given permission for a complete stranger to drive it
sorry dude...
ylwgtr2,
The car was interstate and its hard for me to get time off work to go and see it so that's why these companies exist. I should've got it towed from his place to Devonport, that's my mistake....I guess you can't be too trusting these days.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
