111 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 41
last time i checked the local exchange rate on the "kw" was about $5 per 1kw, but on the stock exchange things move so quickly so dont quote me on that.
in all seriousness you cant just turn money into an exact kw figure. There are a whole host of different and expensive or cheap mods that can be done for power, ie an exhaust would probably gain more than 10kw or it could gain less it all depends on too many factors
Exhaust, Full from turbo back.... $1700 maybe 20 kw gain at wheels.
$85 per kilowatt.
Power FC plus tune, $1500, 25 kw at wheels
$60 per kilowatt.
My piece of string is this long ------------------------------
How long's yours?
who said id had to cost alot? just getting more air in helps, and just a basic tune up(as guerilla said) big turbos, engine rebuilds and the like are more in everyway, so i guess the more you want the more itll cost you. now im just stating the obvious.. :uhh:
Depends where you are in the upgrade path. You can't put a bleed vlave and filter on a car that already has one. If you've upped the boost, changed filter, full exhaust and engine management there's not much around to get your gain that's cheap.
The quickest and one of the cheapest ways to up the boost is a T peice bleed valve.
With stock cooler I would recommend 10psi.. with aftermarket front mount up to 12psi.
To run approx. 180rwkw I would suggest a pod filter, 3" turbo back exhaust, FMIC, bleed valve at 12psi. With that easily 180rwkw.
If you want to hit the 200rwkw then go the Apexi PFC.
Custom mild steel 3" Exhaust $1000 approx.
Pod filter $100 - $150
Bleed valve $100
FMIC bolt on kit $1200 (nengun - Greedy)
Apexi PFC $1500 approx (plus tune)
Hope thats of some use.
10kW out of stock R33...pretty cheap....10kW more out of a worked skyline already putting out bigger figures......quite expensive
as i read above some where, all depends on where your at with your tunning. Air pod & bleed valve will gain over 10kW on a stocker, not so easy at the higher end of the kW figures, maybe bigger turbo? maybe rebuilding or balancing the motor? Not cheap!
so i dont think it can really be judged in $$ terms
jaycar boost controller and AFR adjuster with hand controller.. about $200 all up. Sydneykid installed these recently in his stock stagea and got 30% increase in power with only a small boost increase and better AF rations.
    • UPDATE: Hi all!  As we are getting towards the end of this thread where I’ll showcase final dyno numbers and graph, I wanted to provide an update. Tao from HyperGear has done an amazing job building the custom divided T3 housing for the G30. Communication was flawless, price was great, and now the housing is estimated to arrive in 7-10 days! Very very pleased. I must add, if someone is looking for an affordable turbo and end up reading this thread, I would recommend HyperGear. Genuine brands are the way to go as their reliability is proven, performance can be predictable, and there’s a plethora of information available for specs, flow, and more. This HyperGear recommendation is based on their excellent communication, dedication, and willingness to listen to their customers. I particularly liked their ability to create custom adaptations tailored to specific needs, which is a HUGE benefit over other brands. And if we consider the HyperGear provided dyno results, it adds reassurance knowing their turbos can compete against genuine brands. Next update will be after the dyno!
    • I've previously seen people post up "dress up bolt kits" for RBs but don't remember seeing them specify the full contents. I can only really suggest you grab the verniers and start measuring, and keep in mind the cam cover and timing cover bolts are both quite specific with a wider unthreaded section where the bushes sit, that will make it hard to get aftermarket replacements which tend to be all thread (set screws) or for longer bolts a flat section with a shorter threaded section at the end
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
    • Hi all! Looking to relocate the battery to the trunk of an R34 GTT. I want to do it using as many stock GTR components as I can (including the harness protectors from the 34 GTR that run underneath along the chassis to the engine bay). So far I’ve purchased the battery tray from a 33 GTR, as the captive weld nuts are already there just asking to be used. There is also the slight issue of now having to relocate the ABS/TC/Fuel Pump Control ECU, which in GTT’s sits right above where the battery will then sit on the tray. Has anyone already achieved this, and if you have any pics that you wouldn’t mind sharing? It would be great to see how others have done it and where you put them, as there are countless holes in the parcel shelf panel to potentially use. Just trying to get some ideas bounced around, and to help uncover any potential problems I may encounter by  my choice of location. TIA for any help!
