does any one no how to check ignition timeing properly as i have found pick up wire for timeing light iductive pick up lead to go onto and have checked timeing mark and from what i see is that my timeing over advanced it is at least 20 digrees which is very high is it possible that with this model do i have to bridge my diagnostics plug or something as i think the computer is controling the timeing and i need to check acurate timeing i pretty certain timeing is ok as cam sensor shows no sighn of being moved and engine does not predetinate or any thing but very curiouse that with this model you need to use scan tool to put engine into tune mode to carry out the check.
https://www.sau.com.au/forums/topic/66759-ignition-timeing-r34/
umm, check the NSW section
i think abo bob posted a thread bout it
do a search there
cheers for that guys i will check it out hope it works as i prefer to service my own cars as i dont trust garages hear in nz as they are just to slap happy i see it all the time as i am a diesel mechanic the only problem is my car has warranty on it and i have to have it serviced by a nominated garage.I always check my car top to bottom after its had a service .pretty sad isnt it ,what happened to good tradesman these day.
    • All of your suspension bushes/bolts etc, should also only ever be tightened when the car is sitting with full weight too.   IE, jack it back up, shove a heap of stuff down so you can lower the wheels onto so the car is "on the ground" but you have room to get under it.   It's why when properly done, you should be able to remove the shock and spring, but the arms won't go to 100% droop. If you don't do the above, you'll destroy your bushes.
    • We have some more genuine Japanese legally decommissioned car number plates in stock 🙂, as well as the plain white 40mm hole cover: Tama 400 No 12-41: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-no-1241 Morioka 300 Te 43-58: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-te-4358 Plain White 40mm Hole Cover: https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-40mm-hole-cover-white There's also a yellow plate for Kei cars with the corresponding yellow 40mm hole cover sold as a set: Tsukuba 581 Ii 64-66: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-single-number-plate-ii-6466 Also some Skyline 1/43 scale models: 1989 BNR32 Nissan Skyline GT-R (Silver): https://www.oemsoko.co.jp/products/rare-ebbro-oldies-2006-release-bnr32-nissan-skyline-gtr-silver 1989 HCR32 Nissan Skyline GTS-t Type M (Red): https://www.oemsoko.co.jp/products/kyosho-original-1-43-hcr32-nissan-skyline-gts-t-type-m-red
    • These arrived today! Sadly I'm going to probably be smart and enjoy the car as is over the summer/sunny period and save the ~2 weeks downtime it'd take to swap the heads over and tune later in the year. Maybe. It's going to be pretty damn tempting seeing these bolt on funs just sitting in storage when they're ready to go. There's a non-zero chance I end up @The Bogan'ing it.
    • MZ11 Toyota Soarer in Iwata, Higashi Osaka
