I went down last night. The strip was cr*p in my opinion. Best i got was 14.1
Same with my mates Silvia who has got 13.6 before, couldnt crack 13s last night.
A few lines down there including a R33 GTST with GTR rims, kit and badges :P
And a white R34 GTT, with the worst bodykit i ever saw. The rear wing was terrible. (no offence just my opinion)
Oh and in the carpark was a R33 GTR N1....with plates [R33 GTR N1]
My suggestion is to wait until winter again. Unfortunately its 4+ months away, but hardly anyone turns up on the sunday day drag meets and the track will be heaps stickier cos hardly anyone is going down it. Every wednesday night drag, 3 times now, the track has been shithouse because 100+ cars are going down it and the sticky stuff just wears off. Last-time I went I had so much wheelspin and lack of traction from 1st to 3rd I almost had a close look at the concrete barrier (I think my tyre pressure was well above what it should be as well after the 3 runs I had done previously). So I think I'll wait to they start the sunday day drags again and go down with a tyre pressure gauge and a portable pump and let the rears down to ~20-22psi. Plus I'm sick of paying $30 to get in 4 or 5 runs, when the first sunday I went I got at least 16 runs.
Rob
I had 4 runs;
run1: [email protected]. 60' 2.449. 660' 9.323
run2: [email protected]. 60' 2.578. 660' 9.493
run3: [email protected]. 60' 2.466. 660' 9.467
run4: [email protected]. 60' 2.592. 660' 10.956
On the last run I crossed into the other lane and which time I took my foot off the accelerator and corrected the car and then put my foot back down. I'm sure its due to way too much tyre pressure on the last run and lack of sticky shit on track. Just prior to my 4th run some guy put his into the wall from the same track I was in. Rev210 ran 2 x 14.3's, then dropped his tyre pressure to 20psi and ran a 13.8. Our cars are reasonably simular in the way they are modified. So I'm gonna wait till sunday day drags again and drop the pressure and try again.
Rob
Originally posted by GOT BOOST
13.9 last run
mate lent some potenza race compound tyres traction was heaps better. but didnt seem to have the topend pull it had before.
back to drawin board in turbo department.
What boost are you running?
I have some experience with different turbo mixes PM me if u like
The Key is to keep what youve done on the comp side and hiflo the exhaust side I have T4 2.16 inch ex wheel but this is slightly too big as it looks like ive missmatched it and will need an external gate. Go between a T3 wheel and a vtrim T4 and should be sweet so u dont have to change dump or feeds by keeping same ex housing :P
Originally posted by rob77
I had 4 runs;
Rob
So not quite in the 13s yet....
My 60' times are similar to yours but with a bit more power than yourself i have to look towards keeping her on the road..
Gonna have a bash next wednesday and see what i can do!
Why did u inflate your tyres again on the last one?
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
