I had nearly forgotten about this car, is sitting in storage and hasn't moved in a few months... so gotta try and sell it again.
This car has been setup for circuit racing, although it's proving itself to be quite capable over the quarter mile as well. Car was bought privately in Japan through a friend, was not through an auction or car yard. I imported the car myself, and rarely drive it due to work commitments (working 7 days/on call 24hrs). As an example I have done 5,000k's in the last 24 months. Has got 45,000k's on the odometer. Car is a '96 model.
Engine
Custom low mount exhaust manifold, ceramic coated
HKS 3040 turbo
Trust type R wastegate
BNR34 front mount intercooler
Greddy intake plenum
Q45 throttle body
550cc injectors
Aftermarket metal head gasket
256 intake 264 exhaust cams
HKS adjustable exhaust cam gear
Greddy type S blow off valve
Q45 air flow meter
HKS pod filter
OS Twin plate clutch
PowerFC + Hand controller
Nismo 3 inch straight through exhaust + screamer pipe
Remote oil cooler
Suspension
Full Nismo circuit link kit
Adjustable heim jointed caster rods
Solid aluminium rear cradle bushings
HKS Hyper D fully adjustable coil overs
Apexi front strut brace, GT-R rear brace
17inch Work Equip rims
Interior
Full R33 GT-R interior (front + back seats, instrument cluster)
HKS boost gauge
CD stacker
Exterior
Factory White QM1
GT-R fibreglass front bar
Ganodor electric mirrors
Sunroof
Removed rear spoiler with holes welded + repainted
No body kit (apart from front bar)
Factory mud guards!
Factory "Skyline" optional light at rear
This car has done a best time of 12.09 @ 123 mph, has alot more in it (time was done first time ever drag racing, at Drag Combat Final last year). There's more to be gained from tuning as well, cam timing still hasn't been touched and is running only moderate boost.
In the current state of tune it's make 265rwkw @ 14psi. At 17psi it made 287rwkw. At drag combat was running with a 259rwkw tune.
Offers around $28,000. Will be going out tomorrow to take pics of it. Car is located in Sydney.
https://www.sau.com.au/forums/topic/66780-modified-series-2-ecr33-for-sale/
  • 1 month later...
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
    • Silly question, as I bet you've checked already, but the motor turns over by hand yes? I suspect Neil has a spare starter, though if not, I believe I have a spare R33 (or two) starter.
    • Yeah just run one of those posts to the Link like GTSBoy said. From google it looks like a "mishimoto boost controller" is a manual boost controller. Since you already have the link just buy any MAC valve and plumb it in where the mishimoto is now. Wires to the solenoid should come from the Link's / standard loom boost control wiring (I guess you have an r32, not sure if it is gtst or gtr, if it is GTR where is a 2 pin connector near the engine bay fuse box/injector resistor for that purpose, assuming the standard boost controller is gone)
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
