Just wondering if the factory water-oil cooler that sits between the filter and block is any good? I understand they are not the best but do they have a tendancy to deteriorate and fail in any way? I can get one for next to nothing but just wanted to know if anyone has had issues with them. Thanks.
https://www.sau.com.au/forums/topic/66837-factory-oil-cooler-crap/
doesn't your car have one? the work like this.
when oil is cool, the water flowing through it will help bring oil up to temp
when oil is hot, the water flowing through it well *try* to bring oil temp down. This has a negative effect on the water temp.
I certainly wouldn't put one on a car as an 'upgrade'. if you want an oil cooler the best choice is an air cooled core.
No I have an RB30. I do not want to use an air-oil cooler on a wet sumped motor as if a puncture or leakage occurs oil will piss out due to it being under pressure. It will be an upgrade due to the fact that the RB30s have no cooler standard and something is better than nothing in this case. Unless of course they deteriorate or fail in some way which is what I'm trying to find out. ANYONE??
Hi Luke,
I've never heard/read anything about them failing.
Alot of line owners here would probally be lucky to even know they have a water based oil cooler on their engines.
So i don't think you will get the answer you require.
But im sure if they were prone to leaking, it would be questioned on here, which i have never read about on here, which must mean they are relatively trouble free.
I do think the biggest advantage over the little/moderate cooling it will do, is bringing the oil up to temp quickly to help protect the motor. Only really relevant on a road car, where it can take a little while to warm up.
Not an issue on a track car etc.
I wouldn't expect one of these coolers to really cool the oil, mainly stabilize the oil temps at moderate power/load.
Thanks a lot for the answer. I understand what you mean. I do think it will help cooling a bit but. I have a bit of a test mule RB30 and when you get high oil temp its almost impossible to get it to go away! I swear if you leave it overnight after a good flogging its still got hot oil! But seriously I just like to have something there to cool the oil as opposed to the Rb30s which are just a sealed system. Hey maybe i could fin the sump. lol.
don't laugh luke - i am seriously considering putting cooling fins on the sump! what's your objection to using an oil/air cooler say mounted in the spare area in front of the right front wheel? don't say the option of leaking because if you use proper fittings and lines like speedflow jobs and high-pressure braided line it won't be an issue. more oil flow resistance could be a problem, what oil pump are you using?
Hi luke, I have been running wet sumps with oil coolers of all kinds for many, many years and never had a hose fail. I use good quality hoses and fittings of course. Mazda rotories have had standard oil coolers for 35 years with engine oil pressure running through the hoses. They don't have problems either, so I don't see why you should.
This is a diagram of a Peterson 5 Stage Dry Sump system, you will notice that the feed to the cooler (from the pump) is under engine oil pressure;
So even going dry sump will not save you from having engine oil pressure in your oil cooler and its lines.
Why would they set it up like that? On the BDAs and other cosworth stuff they run the cooler between the scavenge outlet and the tank which makes sense because then if a rock or some debris hits the cooler and splits it (I wasn't actually talking about hose failures as I generally only use speedflow stuff) then it will leak out slowly and will last a little while as opposed to wet sump in which case you have very little time to shut down the motor to save your big ends.
Niel- I'm using a GTS-t pump which is similar in size to a VLT pump but bigger. I don't really want the little thing to be pushing through a cooler and lines as well.
mah grammar ist goot today. haha just taking the piss. yeah i was going to get a 25T pump as well, just waiting for one to show up for cheap. plus i don't need mine to feed a turbo, just twin cams. was going to use an oil cooler front-mounted somewhere too.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
