Help
I want to put some wires through the firewall but can't find anywhere, have tried going through the main wiring grommet but no go. I don't mind drilling a new hole but where is safe? next to accelerator pedal? or has anyone found another way? I am only putting some gauge wires through and would prefer going through a grommet in the firewall old or new.
Thanks
Gary
https://www.sau.com.au/forums/topic/66865-wiring/
When we wired my boost gauge we went through one on the passenger side. Sort of in the middle of the passenger side halfway up. Does that make sense? I'll see if I can get a pic of the wires going through it. We had to get some wires and a small plug through and it was no probs at all. We did have to make a nick in the grommet though.
https://www.sau.com.au/forums/topic/66865-wiring/#findComment-1243403
