i like a wide array of music
Linkin Park, Blink 182, Greenday, Offspring, Good Charlotte, Simple Plan, Bloodhound Gang, Moby, The Rat Pack (sinatra,martin, davis jr, lawford & bishop), Eminem, Dr Dre, Hunters and Collectors, Phil Collins, N*E*R*D, Tenacious D, Sum 41.
They are all my Faves ATM occasionally a new person gets in there and fades out :)
https://www.sau.com.au/forums/topic/66897-music/page/2/#findComment-1251983
hey guys, never posted on here before, so maybe I will start :rant:
went on the last SAUWA cruise, was in the white 31 skyline coupe.
anyways music.... just reading this caught my eye, you guys like bliss n eso?
I am quite into Aussie hiphop, bliss n eso is a fave of mine atm.
can listen to almost any type of music though, except for some heavy metal I guess
https://www.sau.com.au/forums/topic/66897-music/page/2/#findComment-1252972
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
