53 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Do what I did. I went factory Nissan black with a blue pearl thru the clear coat. I have never seen another car with exactly the same colour :rofl:
Some monkey dinted the front bar after it was resprayed but was no problem for the panel beaters to match the colour exactly.
So go factory burgandy with a pearl thru the clear coat :P
  • Replies 46
That's what i am trying to find, but in a factory colour. What you saw probably wasn't factory.
I think i am just going to give up and just flippin use the R33 burgundy, i am sick of finding a colour then having the sample come out totally different.
Al, skylinegeoff was telling me that half his car is painted in a Holden or Ford colour (forget what it was) but I couldn't tell the difference between the two (the local colour and the Nissan colour).
Probably the Ford "sparkling burgundy" from the AU series falcon. Thanks Shane.
Thanks Pete, will keep an eye out.
holy crap! thats interesting. U shouldn't have told us that now we're going to look *very* closely at Geoff's car next time :cheers:
Al, Buddy, You know you want to paint it candy apple red. Don't be a pu55y just do it and get a name brand paint ( like PPG or house of color if you have robbed that bank) so repairs won't be a hassle.
If you go through life thinking of what could happen you may miss out on life.
just do it
this post sponsored by NIKE.....................................Just Do It
I know this ia a bit off topic, but saw a monaro a couple of days ago with a purple/grey paint. Looked fantastic, anyone else seen this? I think that colour would look ace on a skyline.
It's called Purple Haze: http://www.webwombat.com.au/motoring/news_...ts/4_12_hol.htm
    • Thanks for posting, your engine bay looks tops. I'm fairly sure you posted the wrong video though, I think you were supposed to upload the one from your "private test road" where it's banging off the limiter with the gate open?
    • This is something to be careful of. I did a bit of digging on the NM35, as I spend a lot of time on near brand new cars and CANBus related stuff, which uses the same "OBD2" plug for a fair chunk of making my life easy. The NM35, does NOT support OBD2. The data pin is actually on Pin3, which is a manufacturer specific pin, and requires Consult3 to connect to the NM35. Your low voltage, is either because the NM35 doesn't have 12V to the constant power pin on the J1962 (OBD2) connector, OR, it is attempting the standard comms, (CanBus, K Line, etc) and can't see any voltage on those pins. Some people have had success accessing SOME data from the vehicle on OBD2 specification, using a module that supports KPW. My assumption, like Duncan has stated, it will likely actually be JOBD, where there is some cross over with the OBD2 and JOBD standards. Note, lots of "OBD2" dongles, do NOT support KPW, which is what you need for a lot of Japanese vehicles of this era (And even up until recent years!), EG, Subaru, Suzuki, etc.    The end of this thread is probably worth a read, as some people did find a way to get a display up in the NM35 recently, looks like someone implemented all the stuff needed to make it work. (The right protocols).
    • Depending on the purpose of the car, and how much more fabbing you want to do, and what clearances you have, you could look to raise the motor, which will raise the front diff up. Likely would mean altering the chassis rails etc etc, hence the more fab work you'd need to do. However, this can create issues, not just in clearance with everything fitting under the bonnet, but you've also raised a LOT of weight up in the car, and this will DEFINITELY alter handling characteristics (But, so will how much weight you've already added to the front end). You'll also have to deal with the fact the gearbox to rear diff is now out of alignment too for the tail shaft, and alter the angle of the diff, or deal with a bit of potential vibration. Raising the motor an inch up, is effectively the same as making the whole car sit higher by not lowering it as far. So one inch higher motor, theoretically means you can drop the car an extra inch lower, and maintain the same angles in the CVs. Again, depends on the purpose of the car. If it's a just cruiser on the street car, maybe won't be an issue. If it's meant to be a time attack car, I can see you not wanting to raise the motor. This is just for you to ponder as an idea.
    • Have you not seen geospy.ai? It can now give GPS co ords to within a metre from a photo, even if it's a random photo you take inside. Supposedly at the moment only the government/law enforcement has access to that... Supposedly...
    • I've got the rear ones, they're certainly beefy. I need to take them to my driveshaft guru to check over, he's very fussy about the quality of components so I'll let you know if they are made of cheese by a blind man.   Are you in Australia? A mate just had a set of EN26 shafts made for his K20 Lotus by our fabricator which were quite cheap (compared to Driveshaft Shop) so if you can procure the CV's and draw what you need he'd make them for ~$800 for the pair.
