funkymonkey, Put me down for the following:
Independent Electronic Boost Controller - $48
Digital Fuel Adjuster - $48
Hand Controller for Digital Adjusters - $36
Performance Electronics for Cars - Silicon Chip Publications - $17
= $164 inc GST
Need P+H to metro Brisbane, I'll put the money in your account whenever your ready...
  • Replies 218
I am very interested but would like some feedback from anyone that has used the above.
But......hightly interested in the same as RENSONANCE.
There is a thread in the stagea part of the forum about the DFA and boost controller, sydneykid has used both and got fantastic results.
xRHETTx - Thanks
and for that its convinced me so put me down for:
1) Independent Electronic Boost Controller
2) Digital Fuel Adjuster
3) Hand Controller for Digital Adjusters
4) Performance Electronics for Cars - Silicon Chip Publications
thanks
How does the jaycar boost controller compare to the $500 - $700 mainstream EBC's?
If there just as good put me down!! - have most tuners come accross these?
Cheers
conrad.. you do have to solder them/build them together yourself..
anyhow, wake up monkeyboy!!! none of this talking about a group buy and then disappearing again!
put me down for the group buy shenanigans....
the whole 9 yards.
iEBC - 52.80
DFA - 52.80
HandController - 39.60
Cable - 6.60
Book 18.70
PM when your ready and i'll rifle u some cash ..and arrange details. and reconfirm everything
$170.50 inc GST
Cheers
Matt
Hey guys, sorry, I've been in Sydney for the last week. Will be back in the office on monday so I can place the order then. Please use the discount prices that I posted up (we have enough of each order to qualify for discounts). Also include the GST costs, and if you're not in melbourne, $10 for postage. If you're using netbank, please put your username on the transfer description, so I know who the money's from, and send me a PM with the exact items you want and the correct address to send them to (melbourne people can pick their items up at the next SAUVIC monthly dinner meet).
just pm'd everyone who expressed interest my bank acct details. If you're not using netbank (so you can put your username down) please pm your bank acct number so I can track your payment.
Thanks funky, will get onto it. But one question - when/where is the SAUVIC meet? I've not been to any SAU meets, so I'm new to it... just been searching forums for any info on it but nothing listed I can find. :P
its at the Bell Hotel in South Melbourne, every third Tuesday of the month (19th April)
if we get 5 units of each the cost drops to:
Independent Electronic Boost Controller = $48 + GST
Digital Fuel Adjuster = $48 + GST
Hand Controller for Digital Adjusters = $36 + GST
Intelligent Turbo Timer = $27 + GST
Digital Pulse Adjuster = $48 + GST
So see if you can get lots of 5, otherwise if you're happy with the normal trade price, then I'll put the orders in.
Put me on the list for the Boost Controller & Adjuster handpiece.
How do I pay you.
Cheeers,
Dennis
Just transfered the money then.
You have a PM :)
Cheers.
Rob
Cheers, that's 2 people's order's I've got PM's about with money pending...
Dennis, I'll send you a PM with payment instructions.
Some FAQs that I'm getting PM'ed:
Can you COD... no
Can I pick up the items... only if you're willing to travel to the melbourne metro area
Can I buy later... yes, but you may not get the group volume discount (see different prices I've posted)
Does it work with USB... not to my knowledge
Where can I see any of these items to find out more about them... any Jaycar store
Do you accept paypal... no
How long till I get it... about a week after I recieve payment from the last person in the group.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
