Wheelbase looks too short for track, with the feet protruding beyond the front axle line. Pity, but FSAE and its equivalents worldwide want to try to avoid any resalability for legal reasons. It's a major gripe with the editors of Racecar Engineering Magazine.
You can kind of understand why they are worried about resale as not all teams would produce a solid car and they were never originally designed for high speed track work.
And the safety issue you mentioned with the legs in front of the front axle. Although I believe the US competition insists on the legs behind the axle line.
Interesting you mention the resalability - because it was an issue when I was aquiring the car. The official line is: I gave the team a $1600 donation and I happend to know when they were throwing out an old car. The uni did not want any law suits if I get hurt.
Your right about the wheel base, it is 1540mm which is the smallest the comp in Australia allows. The pedal box is about 100 - 200 mm in front of the front wheels so it limits the events we can run in. It is CAMS approved for motorkana and hill climbs, I know because we used to run it regularly in SE QLD events.
I heard recently that the US comp now requires the wheels to be in front any part of the driver. If that is true, it's a bit of a bummer because the US cars will be at a big disadvantage to the Australian cars, so it will be unlikely any will compete in the Australian comp. It also means the Australian cars will not be able to compete in the US comp.
GTRman1992, do you know what design / safety rules apply at QR private track days?
Edited by JCMarshall_Law
I'm not aware of any speed regulations (it has been some time since I have read any rules), but I sure you know that mtorkana and hillclimbs are not high speed tracks. From memory, thoes tracks are bound by some design rules that limit top speeds anyway.
Yea thats what I was getting at. Maybe they think the car is safe for lower speed events than all out track work.
I spoke to the management at Qld Raceway about it today and they said any non registered cars have to be scrutineered for safety. Its up to the event organser to do a risk assessment etc.
I would be craping myself out on a full sized track. Even on the clubman track at QR, with the right gearing, 200km/h should not be a prob at the end of the straight (just guessing based on our 1/4 mile run with the restrictor in place and low gearing). Your ass is only 50mm off the ground in this thing.
I might have to think about designing some wings if it gets approved for track use.
This has got me thinking - what about those supercarts that run at QR, they are hitting 200km/h and they dont have any sort of chassis or roll bars around the driver, no suspension and the feet are definatly in front of the front wheels. IMO, this thing would be a lot safer.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
