Hi everyone
Selling my gts-t due to financial problems :-(
I bought this car in October last year only with 55000 kms completely standard as i am the first registered owner of it since import and have only done 5000kms since i bought it.
Here's some basics about it:
1996 series 2 gts-t
white
60000kms
twin airbags
abs
all power options
3 point alarm/immobiliser
simota pod filter
3" custom exhaust with lukey cannon style muffler (sounds very nice and not too loud)
boost guage custom mounted into console as shown in pics
RAZO gear knob
rear strut brace
red "skyline" seat covers purchased from Unique Auto Sports
full 400R bodykit (front bar, sideskirts, rear pods, GTR spoiler)
18" Lenso muse wheels which i bought 2 weeks after i purchased the car so they are pretty much brand new
New fuel pump and filter
Never been boosted (7p.s.i)
Exterior is in great condition and paint is perfect
Interior is immaculate apart from the usual slight wear on steering wheel
I also have the standard exhaust and standard airbox to go with the car
Im asking $21500 which i think is fair considering the series 2 market value based on a stock standard model but i am negotiable as it must go.
Here are some pics of it (I must admitt it needs a wash inside and out hehe)
https://www.sau.com.au/forums/topic/66944-fs-1996-series2-gts-t/
  • 4 weeks later...
    • Does it make a difference in your turbo having a shorter life if you have a cat converter as it causes that back pressure versus less/no back pressure with a decat? (Not sure if this is accurate) Also slightly different question if you went from a oem cat to a decat or vice versa will it require a tune? I heard if you change the dump pipe onwards it requires a tune?
    • No. Have only gotten as far as contemplating the task of having to put in the required fairly heavy wiring and fusing to run it (along with the big alternator), and preferring not to. But otherwise, it would be nice to have a little extra freedom as to exactly where the compressor is located and free up some space around the exhaust side of the engine.
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
    • Bit off topic maybe but has anyone had a crack at one of those aftermarket electric compressors ? Bit of a search came up with one put out by Speedy Air Spares. Looks interesting and looks as if you'd have to run a big arse alternator. Found this out after the fact as my air con compressor packed it in and soon after my alternator ! !
    • Yes. Needs new ports. Usually just achieved by screwing an adapter onto them. Be aware that any AC compressor that hasn't been used in a long time will very likely have dried out seals and will not hold gas. Oh, and obviously you will require a new receiver-dryer also.
