Hi guys, I have had an ever increasing number of people ask me about tuning their car without going to a dyno. They may live too far away, not have the budget or they simply may want to do it themselves. I have accumulated a few A/F ratio meters over time. I thought to help guys out, I might rent a couple of them out. They are not too expensive to buy, but the maintenance can be relatively high, you have to clean the lambda sensor and perform calibration regularly.
So......
How many would be interested in renting one for a week for say $100? That would cover maintenance and repairs etc. What you would get is;
*a wide band lambda sensor
*long lead to reach to the tail pipe
*a clamp for holding the lambda sensor in the tail pipe
*a meter and controller with sensor preheating for accuracy
*a mount and vacuum cup for attaching the display to the windscreen
*a cigarette lighter power plug & supply
*a full set of intructions
*a laptop interface and logging software to load (not necessary for tuning)
*all mailed out to you in an aluminium case
What you don't get;
*you are doing the tuning, if you damage your engine it's your problem
*if you get busted breaking the road rules, it's your problem
*I don't have time for dial up support, maybe email would be OK though
*insurance, if you break it or loose it, you pay for it
*a lap top, you supply your own, if you want to do logging
*credit, you pay up front and there will be a deposit (not sure how much yet)
*freight, you have to pay both ways, it's light, so $10 should cover almost anywhere in Oz
*instant supply, I only have 2 suitable units and I don't want to buy more. So you may have to wait until one becomes available
*to use leaded fuel, it must be unleaded
* to send it back dirty and greasy, clean it please
*your deposit refunded until it is received in good condition
This is a survey for me to judge the response, so post away. If I get enough interest I will be ready to go in about 3 weeks, as I would have to clean, service and calibrate the 2 units.
Awsome Idea,
I was charged $50 for 15mins of driving up and down the road I was not impressed I didn't get to load it up in top gears only 2nd gear.
Have you got any Second Hand/New ForSale ?
:P
Nat
If its a brand name unit such as the Autronic model, they are expensive, i say make people leave a deposit of $500 bare minimum, just incase something happens.
Because you know what people are like, hopeless.....
If you have a quality unit for hire now, i will hire it immediately.
$100 is a fair price for a week, + return freight/post to you.
You can get some preety good wide band units off the net now for around $500-$600 with controller, which is a great price if you want to tune your own cars.
Let us know either way.
Cheers
sounds like a very good idea :cheers:
Yep, I know it's a good idea, but how many people would actually rent one for a week for $100? That's the question, if I get enough I will do it. We can then start a thread on people's experiences with tuning on road and the results they get. Should make a good reference for others.
I need a few more to make it worthwhile, so let me know:cheers:
    • Man that dinner was such a long time ago....2010! I would only replace the rubber coolant lines with silicone these days; cheap, readily available and will last for ever. You will need new hose clamps though eg https://justjap.com/products/cooling-pro-silicone-engine-heater-hose-set-black-nissan-r32-gtr-rb26dett
    • I wouldn't look too hard at what they did with the R32 GTR in endurance racing in Australia... Lots of things weren't actually available from the factory in the way those cars ran them... Japan also followed what Fred Gibson was doing here with some of there endurance cars in Japan... Australia is also the reason for things like the Brembo brakes, and the change in the gearbox... And quite a few other tricks they used to pull. There's a few other SAU peeps still on these forums that will have heard the stories direct from Alan Heaphy, Fred Gibson, and Jim Richards when we were lucky enough to have a great dinner with them
    • For all the talk of "these parts are junk" I generally recommend OEM because it's really not as bad as claimed. I have never seen or heard of a case like the N63 where the oil returns completely clog with coked oil for example in ~10 years or less. Would it be nice if it were a straighter path? I guess, but most modern cars use a scavenge pump instead of a pure gravity return. Also the factory lines that would be relatively simple to convert to braided are generally speaking hardlines from the factory. I would consider braided line to be a regression, not an improvement. It's also been engineered such that all the hardlines have appropriate strain relief where needed. There's absolutely room for improvement, for example the HKS advantage heritage intake piping shows just how much can be done to make the turbos fight each other less in OEM twin turbo configuration and reduce compressor surge but it's rarely a simple/straightforward process. I recommend looking at what the group A/N1 cars did, generally speaking the changes they made were necessary and proven in endurance racing.
    • Yes, multi relays needed, and possibly a diode. I'm not actually going to think about it though.
