77 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
the kiwi shipping company damadged my driver door in transport, reversed into something with it open. got a quote to fix dent, front quarter, replace hinge and respray and blend the side at $2500, turns out that kiwi was well aware of the damage as when I reported it they sent me back a picture of the dent and questioned some of the items on the quote.
havent heard back from them in a week so im hoping theyll coff up
I have had RSM's stolen, decks, gauges, and also have had a GTR front bar come down in the back seat in 2 pieces.  Kiwi is the worse when it comes to carelessness.  Their insurance does not cover internal parts.
i agree 100% with u on that one allblitz....my apexi blue screen was taken but i had brand new set of disc rotors aswell as break pads just sitting there in boot was untouched. i just guess thats just part of importing.
hey guys,
i got my stock R34 GTT perfect and untouched... but was is their to grab on a stockie? Didn't have a head unit to begin with so i knew that wasn't taken. Speakers were aftermarket but weren't touched.
Now i'm importing a heavily modified R32 GTR, which i am worried about what's going to get taken. It's got twin z32 afms, safc, head unit, etc, and a lot more. If it lands and everything is still there, i'll be very fortunate. If not, well then what can you do!
mate, you can expect to lose that nice turbo, AFM's and any decent stereo gear as well.... No - jokes. If anything is easy to remove (head unit) then get the supplier to post it air mail to you, also put anything like nice gear knob etc in, as it only costs about $50 for air freight for about 2kg's. better than losing stuff.
Good luck, everything arrived ok in mine.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
    • I did say no low balling (Insert copy and paste article from Motor mag with complete history of R32 GTR development and racing history here)
