Heya Fellas.
Ok there are alot of people with R32 GTRs on the forum and I wanted to know your thoughts on the factory R32 GTR rear wing ... on or off ?
Also I have been asking alot of people about BOVs for the RB26 and I keep getting mixed answers. Do really I need to buy 2 Bovs or can I just fit 1.
Thanks guys,
D
https://www.sau.com.au/forums/topic/66976-r32-gtr-best-look/
Daaaamn! Thanks guys, I will leave it on yeah I guess thats what really makes the Gtr look.
and about the Bovs well I can leave the stocks on I guess but a friend is getting rid of his HKS Sequential Bov and wants like $150 its in good nick.. just wondering if I can use just one or not.
Also does anyone know of any nice skirts and rear pods to fit the R32 GTR. oh and not too hard to find in Oz.?? I'm thinking of getting some from "carmate" for $550 I thought that was cheap is it?
I wouldn't replace the twin factory BOVs with one HKS one. The GTR HKS kit has two BOVs. if you want them just get that. The only GTR kit i've seen with just one is the trust Type R kit and that is one BIG BOV.
It all dpends if the car is going to be kept near stock,
i have seen a couple o "autostyle" cars with the wing removed and just the nismo lip thats looks nuts but i reckon then you need to have buig dished wheels and the car pretty low
my 2 cents
there is no doubt that the rear wing needs to be removed and a nismo lip fitted. Definetly larger aftermarket wheels, (18inch BBS LM wheels look AWSOME!!)
There are a few 450+ rwkw GTR's going around melb with standard 33 GTR BOV's. They work fine, no leakage (and they are STANDARD EQUIPMENT which helps get around defect issues)
I am having the boot holes deleted and fitting a new nismo-tyle lip spoiler.
This is my car before it was shipped to Aus and before the damage to it:
is the lip you have on it now a geunine GTR one that can be fitted along with the OEM spoiler ?
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
