  • Replies 121
Its just that game should be accurate, the powerful real wheel cars do produce wheel spin and can oversteer but the oversteer is not reflected to what happens in real life. You push the directional button hard left or right and floor it and the car will go in a complete circle will out breaking the tail out, to me that dulls the game and makes me think there is to much incorrect understeer programmed in every corner you attack.
https://www.sau.com.au/forums/topic/66989-grand-turismo-4/#findComment-1245485
having the driving force pro helps with drifting as well, but seriously as everyone else said, it's all dependant on vehicle setup and your control of the vehicle.
it's not like the bull in NFSU with it's unrealistic crap drift.
https://www.sau.com.au/forums/topic/66989-grand-turismo-4/#findComment-1245866
lol...yeah same as what duncan said.
"Mike9" when you say that high powered cars create wheelspin to generate oversteer?? do u mean just getting the tail out prior to corner entry??...thats more suspension/tyre setup than power i dont think thats really termed as oversteer, well from what i understand anyways....thats just plain old drifting:D
https://www.sau.com.au/forums/topic/66989-grand-turismo-4/#findComment-1246425
The game is fantastic... so much fun 'drifting' my r32 gts-t around but is anyone else pissed off that EVERY other model is skyline is in this game (including about 10 different varieties of R34 GT-R) but yet there are no R33 GTS25t of R34 GT25t (except the D1 version)????
I mean it's just disappointing not being able to buy the car iown in real life and driving it :D
https://www.sau.com.au/forums/topic/66989-grand-turismo-4/#findComment-1247404
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
