Hey guy,
can someone give me a hand, i am going to install the safc tomorow although,
the manual doesnt match the wiring coming out of the safc lol so i am a lil confused.
can someone take a pic of there ecu and tell me what wires go where. or give me a lil run down.
few things i am unsure about is what wire should be going into the throttle wire on ecu. and someone told me a whire should be going into the knock sensor wire on the ecu also, but this isnt in the manual.
which makes me confused.
my car is a r33 gts-t
thanks
https://www.sau.com.au/forums/topic/67027-safc-install-help-needed/
G'day,
I recently wired a SAFC (blue screen version 1) into my ca18det S13 so I can give you my experience with this unit and hopefully answer some questions. The SAFC doesn't have a knock sensor function (the SAFC2 does) so you won't find a wiring diagram showing it.
Your SAFC should have 10 wires - red, green,grey,black.brown,yellow,white,blue,pink and orange. For your R33 gts-t you won't use the blue, pink or orange wires. The grey wire is the throttle position sensor input. Red is +12V power, balck and brown are ground, green is RPM, white is AFM input and yellow is AFM output.
I recommend you go to the Apexi website www.apexi-usa.com and download the 2 PDF files from the documentation page called electronics_safc_ins.pdf and electronics_safc_wire.pdf. These contain all the information you need. Make sure you read all the warnings before you attempt to install it.
Hope this helps
Kris
i just installed my safc on friday night. d/l the 2 pdf's and its alot easier. it has 2 diagrams for rb25, one for ser 1, one for ser 2, however they are both the same.
also look closely at the wiring and the locations in the connector. there was a few times i questioned which wire it was.
dont rush it and u'll be fine.
cheers
Linton
if you are not busy today i could have a look at it for you as i fitted one to SKA's 33 gtst not long ago..
if your afm isnt workin you would have had troble before you fitted the safc-1
