I'm selling my Class D monoblock. It's rated at 400WRMS at 2ohm, but that's pretty underrated - estimated > 450WRMS. It was running my two Phoenix Gold Tantrum 12's - Pulled 136db on a Termpro meter on moderate gains
A few scratches (Could probably be fixed with a good polish), but in perfect condition. Used for about 1 year. Can be heard in car
RMS Power: 400W x 1 @ 2 Ohms
Speaker Level Inputs: Yes
Preamp Outputs: Yes
Bass Boost: 0-18 dB
High-Efficiency Class D Circuitry
Mosfet Power Supply Transistors
36 dB / Octave Low-Pass Crossover
Fully Adjustable 40-200 Hz Crossover Frequency
Switchable 36 dB / Octave Subsonic Filter
Adjustable Bass Boost
Wide Range Input Sensitivity Adjustment
Soft-start and Muted Turn-off
Thermal, Over Current, Short Circuit, and DC Offset Protection
Power / Protect Indicator
Remote Level Control Capable
Polished Aluminum Heat Sink
Carbon Fiber Finish Heat Shield
User Manual: http://www.coustic.com/classic/PDFs...01_DBManual.pdf
Great sub amp - $300
Audioline 4x200 (Closer to 4x65wrms or 2x200wrms)
* 4 Channel
* Bridgeable and Tri-Mode
* In Built Crossovers
* Overload, Thermal & Short Curcuit Protection.
Specifications
Output Power (MAX) - 200w x 4 Channel
Low Pass Filter - 40hz to 150Hz
High Pass Filter - 80Hz to 1.2kHz
Frequency Response - 5Hz to 50kHz
Stereo Separation - >60dB
Input Sensitivity - 200mV to 2V
Input Impedance - 10K^
Fuse RAting - 30A
This amp was running my Hertz 3 way front stage (8 inch mid, 4.5 and tweeter) - sounded very impressive for what the amp is. Has a few scratches also, will get pics soon.
$80
I would like to sell both for $340.
This would be a great setup for two 4 ohm subs (Or a dual 4 ohm) and front splits system bridging the Audioline amp (Or splits and rears using all four channels). I got many comments about my system sounding great.
Refer to this link for pics http://www.caraudioaustralia.com/forums/sh...ead.php?t=49254
Preamp Outputs: Yes
Bass Boost: 0-18 dB
* 4 Channel
Specifications
Fuse RAting - 30A
$80
BOTH AMPS ARE SOLD!!
