Hi, I had the TE37 17 x 9 wheels on my GTR, the front is 245/40 and rear is 255/40. Today I went to bob jane to ask about new tyres, they said I can put 235 at the front and 255 and the rear. Just want to know is that safe? I'm not driving the GTR very often, coz I got a daily drive car. But I just want to know the difference between the F:235 R:255 and F:245 R:255. Anyone can help?
Also wanna ask the price with these tyres? THx!!!!
Everything I've read says that you need to have EXACTLY the same rolling radius at all 4 corners, else your ATESSA system will have a caniption fit, so that means IDENTICAL rims and tyres.
And for the sake of 10mm extra why bother? just go 245 all round.
No! No! No! The ATTESSA doesn't care about the WIDTH.
The DIAMETER should be the same, but that is NOT the same as width. So you can have 225/45/17's on the front and 255/40/17's on the rear. The rolling circumference will be the same.
PS; if you had done a search you would have found plenty of posts on why this is the case.
what about the width of the WHEEL?
I'd always understood that the GTR should have equal width (and diameter) wheels and tyres front to rear? That would be pretty cool if you can just use different sized wheels/tyres.
I have driven a GTR over 200k's with the space saver spare on the front, the ATTESSA didn't even know. The torque split looked quite normal to me, I even palyed with the torque splt controller, just for fun.:cheers:
No, only tyre circumference needs to be the same as the ATTESA works on front to back wheel speed differences. So you can have those 12" wide deep dish wheels on the back, Richard, so long as the tyre circumference is the same. :cheers:
So what that means is I still can get 255/40/17's at the rear with 235/40/17's at the front? Just have to get the width at the same size? is that what u mean?
Ah no! Perhaps a quick explanation of tyre sizes might help
235 = 235 mm wide
255 = 255 mm wide
40 = 40% of the width (that's the measurement from the outside of the tyre to the rim)
17 = 17 inches, the rim diameter
So 235 X 40% = 94 mm
And 255 X 40% = 102 mm
So they are NOT the same circumference.
If you want 255/40 on the rear (102mm) then you need 235/45 on the front (105mm). Check the alternatives with the tyre shop that you are going to buy your tyres from, they have equivalency charts (so their customers can keep their speedos accurate).:)
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
