Product: APX Super Wheel Nuts
Price: $120AU shipped within Australia
Minimum order: 5 sets
Applications: Nissan, Subaru, Honda, Mitsubishi, Toyota, Daihatsu and Mazda
Descriptions: These come in Red, Blue and Black. Individual weight is 30gm's. APX super-light lug nuts are made from aluminum alloy that is very strong but light (less 50%-60% in weight compared with ordinary steel nuts). Our lug nuts fit all tuner wheels of major Japanese motor models. Each nut has engineered close-end design to prevent rusting. External socket pattern ensures better torque without breakage. Bulge design provides more seating surface than traditional tuner lug nuts.
These only come in sets of 20. Do not torque these over 120nm.
Participants:
01. 3jai - black (nissan)
02. pablo321 - blue (nissan) - paid
03. babia - black (nissan) - paid
04. Duncan - blue (nissan) - paid
05. Scotsman - red (nissan) - paid
06. ZILLAR5 - blue (nissan)
07. INASNT - blue (nissan)
08. lvlong - black (nissan)
09. FAT32 - black (nissan) - paid
https://www.sau.com.au/forums/topic/67042-lightweight-wheel-nuts/
  • Replies 116
Wow, High performance lug nuts. Good idea... if you were a 2005 F1 team chasing down Ferrari in the championship and were currently coming second ;)
Whats next, carbon fiber air valves with titanium end caps?
I dont tighten up my wheel nuts with a torque wrench, and neither do the tyre places.
Tyre places don't use torque wrenches b'cos
1. saves them time
2. they don't care if they over tighten, not their car.
These are light weight wheel nuts, I never claimed whether or not they give performance.
If you're not interested, then why post? Unless I have posted false information?
Ide get them but witout the circle bit pertruding after the actually socketable bit (if that makes sence)
if i used these on my wheels they would stick right out
my current wheel nuts are the same but smaller and fit my mags perfectly
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
