Hey Brendan, Those pics you posted are they of your actual turbos?
as they are different! you will notice that one is a 1-1 and the other is 1-2.
From my experiance the 1-1 are from an R32 GTR, and 1-2 is from an R33 GTR.
Also the .42 is deffinatly different to mine (that were stock 32 GTR ones, but are now stock 33 GTR ones, as mine were/are .24, do they have steel wheels? if they do they may be N1 turbos but normally N1's have a Blanl Rectangle on the outlet of the intake wheel. and I didn't see that on your turbos. Do you have a full pic of the front now the turbos are off?
Cheers!
heya
basicly i didnt think they where n1 turbos either untill i spent a couple of hours taking one of the turbo's off and looking at the serial number which matches the n1 turbos. There do seem to be a few differences- look at the text document below.
I didnt get many pics cos for some reason our $700 digital piece of crap camera takes blurry photos when its dark!
I found this info on the internet N1 -Vs- Stock R33
R32 - R33 Ceramic 14411-24U00
Genuine R33 N1 14411-24U10
Edit - crap that didnt come out properly
www.iinet.net.au/~drath/N1vsStock.txt
Look there..
It sais basicly my exhaust wheels are made out of Inconel.
Inconel refers to a family of trademarked high strength austenitic nickel-chromium-iron alloys that have exceptional anti-corrosion and heat-resistance properties. These alloys contain high levels of nickel and can be thought of as super-stainless steels. Inconel alloys are used for a variety of extreme applications including navy boat exhaust ducts, submarine propulsion motors, undersea cable sheathing, heat exchanger tubing and gas turbine shroud rings.
    • I’m hosting a bunch of execs in the McLaren box on Saturday. If you’re around I’ll come say hi, and see if I can sneak out some freebies.
    • Yes. All of this. But even when you get the NOx as low as you can go on an RB, it will no doubt still be way too high. Same with CO and HCs. The tech and the tuning time just isn't there.
    • Dang. I love the little 'oil used' bingo card on the side.   🤣  Well, now they can use a box and an oil-filled goon.
    • Many many moons ago, I was chatting with Andy Wyatt, about his auto ignition tuning. One of the HUGE things he said to me, when tuning for power, right where you hit peak ignition timing for your max torque, dramatically increases NOx emissions. He was finding in testing, particularly on engines you could advance timing beyond peak torque, that backing the ignition timing off a couple of degrees only made for a small drop in torque (compared to if you keep backing it off further the same amount of degrees) but dramatically reduced NOx emissions. I'd say targetting for 14.7, and he's even mentioned in some scenarios going slightly leaner, and pulling a few degrees of IGN timing will help pass for emissions quite a lot. However, who tunes an RB for emissions
    • The main stuff from.Vibrant I see is more their intercooler piping, and everyone raving about their clamps, but when I looked it was about $150 per clamp... I was a bit   I also thought the public price SP had up was high. As Mark said, a normal exhaust shop can fab them. It was many years ago that I had a full exhaust built, but for a full turbo back exhaust, and 2 custom built mufflers, plus a high flow cat, was about $1,100, and that was fully installed, drive in, drive out. I believe SP was about $900 for 2 mufflers, just supplied   These days, I just buy the material and built it myself, because I need to stretch my $$$
