Have u find it? ModYourCar.com (http://www.modyourcar.com.au sells that stuff for $990, Justjap in Sydney sells for $995 (http://www.justjap.com ,then parts in stock, new parts, engine parts). Sorry I don't have any idea for Vic if you live there, but in my opinion, there should be several shops selling that stuff.
