Hi, just wondering what things are require to re-register a complied import.
I'm looking at buying a 15year old R32 which has been complied and I want to know that I have everything required, so that when I rock up at QLD transport, with a RWC and cash for Rego and CTP insurance I'm not going to be turned away.
So what items could be required?
* A japanese complience plate? (the Blue sqare-ish ones)
* An Australian VIN number (ones that are usually engraved onto the fire wall or on a pop-rivited plate)
* The Australian complience plate (that reads "this vehicle complies with the low volume import rules of 1989" )- I've seen these on later model cars, like R33s etc. Are these required for the 1989 model cars?
What about paper work??
* Import approval paper work
* Complience paper work?
Thanks.
https://www.sau.com.au/forums/topic/67067-purchasing-a-complied-car-within-aus/
all they checked on my car was the complience plate, safety cert.
VIN number, theyalso check that the VIN number is registered on some system.. its called something like NAVDAS.
i also gave a copy of ID, and import approval but i dont kknow if thats needed
when i went to rego my car that i imported, i had a trainee doing it with a more knowlageble working standing behind him explaining things as he went, as he had not done an imported car before.
from what i heard, they basically entered the car into the system, cleared all the details (as in going out to look at all the right things) and made sure all the new details of the car (VIN etc) were ok and put them into the system.
form this, i would not thing there would be much needed other then your normal things to rego a car built in aus, as everything was cleared that first time, and the car is now on their system.
but, this is just my thoughts, obviously a call to your local main roads would give a more solid answer :D
shaun.
1) A japanese complience plate? (the Blue sqare-ish ones)
2) An Australian VIN number (ones that are usually engraved onto the fire wall or on a pop-rivited plate)
3) The Australian complience plate (that reads "this vehicle complies with the low volume import rules of 1989" )- I've seen these on later model cars, like R33s etc. Are these required for the 1989 model cars?
1) If you mean "engineers plate", yes you need that. This is different to an official compliance plate as on the SEVS or older system for cars newer than 15 years. It basically says "this vehicle meets ADR's for 1989"
2) yes, you will need the aussie VIN attached to the firewall, which is at the bottom of your import approval.
3) See point 1).. no.
I registered mine after compliance.. there were a few confusing stories I got, but in the end I spoke to the manager at QLD transport, and what i thought was correct.
You basically just need the above, a valid safety cert, the CTP papers, and your import approval (they check this). That is all you will need. You will have to also pay stamp duty, and a little bit extra for the issue of new plates.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
