I have just worked out that wire 53 (speed sensor for the ecu) has been cut, cause my HICAS light comes on all the time, and i can do over 180. But i checked the ecu, and no wires were cut there. Is there any other places people have found the wire cut?
Thanks
https://www.sau.com.au/forums/topic/67089-places-that-wire-53-is-cut/
The speed sensor is on the back of the dash cluster. Check for continuity between the plug on the back of the dash and the ecu,if you get nothing then run a new wire, if its ok, check the pcb on the back of the cluster for a broken track, if this is ok then look at getting a new sender.
Note, early and late model dashes have different senders on GTSt's so check your's before getting a new one (if you have to).
